Convertible top switch
^^ This. Find the fuse for the top on the fuse box, ground the tester, prob the contacts. If you have power on both side of the fuse, it is either a wiring problem or a switch issue. The switch is hard to reach because it is connected to the dash plastic behind the air conditioning duct. You nearly have to pull the dash out to get to it.
while recharging the hydraulic system, the top motor (pump) would continue to run when the switch was reversed or when I tried to stop it. sometimes it would start, but now nothing.
I'll check power & fuse. I sure don't want to remove the dash
Thanks for the responses.
Top Switch
If you have to open the system, (switch is good but pump is bad) try this ... https://store.convertibleparts.com/f...atic-tool.html I used it to fill / bleed the system if you need to change a pump or pistons, I installed a new top motor and this was an easy one man job to fill and get the air out of the system with no mess.
