69 Cutlass S Convertible Rear Speaker
Old Mar 4, 2009 | 07:47 AM
  #41
Lady72nRob71's Avatar
Originally Posted by Bluevista
As long as the subject is electronical, riddle me this.
If you put a cassette to 8-track adapter into an 8-track with a cassette MP3 adapter in it that in turn is plugged into an Ipod or the like will it work????? Sort of the long way around the block.
This should work, but the ipod puts out a much lower signal than the typical walkman of the days. Therefore, the sound volume will be lower.
Even many cheapo mp3 players put out higher signals than the ipod.
I run my ipod into the AUX-in of my 200lb Magnavox console stereo and I cannot crank it up all that loud. But put on the LPs and it will rock the house and vibrate the concrete floor...
I use the FM transmitter to play my ipod through Lady's sound system - works great. I installed a hidden switched 12V outlet in the glove box to plug the transmitter and ran a cable from it to the ash tray where my nano resides. Totally hidden.
I have seen AM adapters, too, so you can play your ipod through an AM radio.
Old Mar 4, 2009 | 08:17 AM
  #42
As I gaze into my crystal ball, I see and smell burning wire in the near future?
Rednecks famous last words.
"Ya'll gotta watch dis."
Old Mar 4, 2009 | 09:27 AM
  #43
Not from my car (any more)... I rewired it correctly!
One of the previous owners had a CB adapter wired to the radio, and the radio's power antenna lead connected to a FET switch connected to the cigar lighter... I wish I had known about this odd hookup before I had the radio on and pushed in the lighter...
Imagine driving at 40mph with a plume of acrid black smoke emerging from under the dash... That FET was burned clean off the PC board.
As Donald Duck would say with his famous accent, "What a mess...!"
Old Mar 4, 2009 | 10:14 AM
  #44
Bluevista's Avatar
Registered
The FM transmitter sounds a lot easier.
That Rube Goldberg set-up would probably start a fire or I'd get done blowed up good.
If I can find the stuff to do it cheap at the flea market I'll be a daredevil and give it a try in an ignorant friends car.
Should just go the other way and get an 8-track recorder and make my own tapes.
I could probably fill the car solid and drag a trailer full of them and still not have anywhere near the songs you could fit on an MP3 player.
I'm just a lonely analog guy in a crowded digital world.
Is that a country song?
Old Mar 4, 2009 | 11:24 AM
  #45
That FET switch was not just burned up, it was burnt-slap-up (southern term for costing more money to fix)...
I have an 8-track recorder at home but that is also the only working player I have, also...
Old Mar 4, 2009 | 01:51 PM
  #46
dingusboy's Avatar
Red face
FM transmitters get a lot of interference. You always seem to be adjusting the station. Has anyone tried this. www.rediscoverradio.com It seems a bit easier. In theory you could hook up CD players, FM radios (if your radio is not equipped), mp3, Ipod, Sirius, etc. I was thinking of doing a radio conversion, but the limitation on speaker placement made me feel like I was not really preserving the original aesthetics. If the sound is always going to be limited by the original speaker placement, then I might as well give it a try.
Sam Barrett
Nov 22, 2014 12:39 PM
KERTWOOD
Mar 4, 2012 02:50 PM
stlbluesbrother
Sep 5, 2011 10:59 AM
danimal442
Jan 19, 2011 02:51 AM
bcg88
Oct 11, 2008 10:42 AM
