69 Cutlass S, breaklight wont work, electrical problem
Old Oct 14, 2006 | 03:13 PM
craftsmen22's Avatar
Cutlass driver in Germany
I recently got a 69 Cutlass S conv. and I checked the lights after people told me my passenger side tail breaklight would not work. I changed the bulb and checked for ground, no light. But the turn light will work.
Driver side tail light is good both the breaklight and the turnlight, but if I push the hazzard button both front turn lights work and none of the turn light in the rear.
I checked the break switchcable, seems to be okay, got power on the cable when I push the pedal. How to hunt the problem down. Break and turn modus use the same wire, so why would break contact not come?
Please help, thank you.
craftsmen22
Old Oct 15, 2006 | 05:49 AM
ozoneblue's Avatar
Brake lights
The brake lights & turn signals are all seperated at the T/S switch take off steerng wheel & try spraying some electrial cleaner on switch while operating it
Old Oct 16, 2006 | 01:36 AM
Brake light
Thanks for the reply. I did take down the steering wheel and I found a spring which came out of the socket. I put it back in and the lights work fine.
Once again,
Thank you.
craftsmen22
smkn600ctd
Dec 29, 2014 05:38 PM
cmfjay
Sep 16, 2014 04:50 PM
nightmare
Jun 21, 2012 12:23 PM
rroth01
Apr 17, 2010 02:38 PM
mainedogg72
Dec 12, 2006 04:45 PM
