69 Cutlass S, breaklight wont work, electrical problem
Old October 14th, 2006, 03:13 PM
Cutlass driver in Germany
craftsmen22's Avatar
I recently got a 69 Cutlass S conv. and I checked the lights after people told me my passenger side tail breaklight would not work. I changed the bulb and checked for ground, no light. But the turn light will work.
Driver side tail light is good both the breaklight and the turnlight, but if I push the hazzard button both front turn lights work and none of the turn light in the rear.
I checked the break switchcable, seems to be okay, got power on the cable when I push the pedal. How to hunt the problem down. Break and turn modus use the same wire, so why would break contact not come?
Please help, thank you.
craftsmen22
craftsmen22 is offline
Old October 15th, 2006, 05:49 AM
ozoneblue's Avatar
Brake lights
The brake lights & turn signals are all seperated at the T/S switch take off steerng wheel & try spraying some electrial cleaner on switch while operating it
ozoneblue is offline
Old October 16th, 2006, 01:36 AM
Brake light
Thanks for the reply. I did take down the steering wheel and I found a spring which came out of the socket. I put it back in and the lights work fine.
Once again,
Thank you.
craftsmen22
smkn600ctd
December 29th, 2014 05:38 PM
cmfjay
September 16th, 2014 04:50 PM
nightmare
June 21st, 2012 12:23 PM
rroth01
April 17th, 2010 02:38 PM
mainedogg72
December 12th, 2006 04:45 PM
Quick Reply: 69 Cutlass S, breaklight wont work, electrical problem
