69 442 soft horn
69 442 soft horn
My horn sounds, but very softly. Is this a horn relay issue?
Additionally, I need to R&R my turn signal cancels, Does the horn cap pull straight off?
I pulled firmly but no go, I dont want to force it and break something.
I suspect there may be 3 pedals under the dash. Unless I missed it in prior posts, I didn't realize it's a 4-speed? That makes it more special in my book.
IMMIC the horn button is a pull off. If I'm wrong others will chime in. Happy Motoring!
Try a little no-cost troubleshooting before replacing any parts. Run a jumper wire directly from the battery to each horn and listen to them. It they sound correct that way, then the problem is low voltage to the horns, which could be anything from the wire, to the relay, to the power source. If the direct wiring to the horns is still too soft, then it's either the horns or the grounds where they bolt to the core support or the core support to the rest of the car.
Thanks for the advice, I guess I'll give it a little more umph pulling on the horn button
Yes that's solid advice, I'll do just that.
Thanks Joe
https://www.google.com/imgres?imgurl...MygOegUIARDlAQ
use a plastic orange peeler or similar to gently pry the cap off go from the bottom or start the car and flip the wheel over
just in case of a slipnscuff
if your horns whimpy I can help you possibly wake em up ,,, you have 2 of them a high and a low ... powered by a green wire ,,,,
also loosen the bolt and resnug.... sometimes its a ground issue but not often
if they are still whimpy after jumping them give me a ring 2o6 4six5 9165 I have a couple things you can try
69-72 cutlass horns interchange ,,, all 4 years so someone may have loud horns stashed for you , I just sold my last pair,,,
4 speed ac console lookin gooood !!!
Scott
Scott
Great stuff, thank you!!
I'm talking with another member right now and I'm going to buy the olds bible from him.
This diagram is just what I'm looking for
Next chance I get, I'll start on these issues,
and perhaps give you a ring if I get stuck.
