‘68 Cutlass won’t start, then starts
Old Nov 22, 2021 | 11:48 AM
jurrasicpork's Avatar
Long story short, every 1st attempt at starting my ‘68 there’s one click & no start. Second attempt she fires right up. Cold start, hot start, doesn’t matter. I’m at a complete loss as to what the issue is but I know it’s only a matter of time before I get stranded somewhere. Any advice is greatly appreciated!
.60 over Olds 350 w/HEI, everything else stock under the hood.
Old Nov 22, 2021 | 12:36 PM
stellar's Avatar
stellar
Probably a connection dirty or loose. Check battery connections starter connection ground at block. If that isn't it maybe time for a solenoid, or starter rebuild.
Old Nov 22, 2021 | 01:41 PM
^^^THIS. Verify all connections are tight and clean first (including battery terminals and ground wire to the block. Also, ensure that the purple wire start circuit has good connections including at the NSS and firewall connector. A voltage drop test while cranking is the best way to check this. Failing that, it's time for a solenoid.
Old Nov 22, 2021 | 09:51 PM
awesome, I’ll give it a go. Thanks!
sixtyfourbeets
Cars Wanted
Oct 22, 2021 06:33 AM
Oldsmaniac
Oct 22, 2016 11:22 AM
RROLDSX
Nov 22, 2013 09:44 AM
68Dreams
Feb 25, 2013 07:34 PM
yeahbuddy
Jun 29, 2010 09:48 AM
