68 cutlass turn signals not working
If there is a trouble shooting thread in here I would appreciate a link. Turn signals worked fine one day, next the lights don't flash but do come on. If I manually move the turn signal lever I can make them turn on and off. Checked all grounds with a meter. Replaced the flasher relay, found one bulb with a burnt filament, replaced that and inspected all sockets which are not corroded etc. Hazards do not work either, but all tail/parking/running lights do. Could the problem be in the column / lever?
Thanks in advance.
Thanks in advance.
The no-flash situation is normal when a bulb burns out. If the bulbs are fine, replace the flasher module. Keep in mind that the turn signal flasher module is NOT the one you see on the fuse box, it's up under the dash to the left of the steering column.
thanks joe, I’ll crawl under the dash and find it, does it look similar to the fuse box relay?
So I’ve been under the dash for a good half hour and there is nothing, no pigtail, no module. Any idea what color wires go to the module? That might help. I noticed a turn signal fuse in the fuse box, it is Not burnt.
A purple wire and a green with white stripe. It's outboard of the steering column, about above your left leg if you were sitting in the driver's seat.
found it, buried up and over the parking brake handle tucked behind the top of the kick panel. Off to get a new one. Thanks joe
September 24th, 2017 12:56 PM
