68 cutlass gauge lights not working
Old Mar 24, 2014 | 02:38 PM
Cortez1888's Avatar
I have a 68 cutlass vert, and all electrical works, but gauge cluster. No lights come on etc brake, gen, oil, hot. The panel light comes on for the speedometer. My gas indicator is past full. I have ordered sending unit to trunk harness, it was cut. I looked under dash and all is plugged except a pink and orange harness connector that i have no clue where its goes. Its also a brown wire with whites stripes down the side. Can someone help me out.
Old Mar 24, 2014 | 03:40 PM
freds cutty's Avatar
I can try to help you the reason your lights don't work is more than likely a ground issue. Check your ground at the gauges also the pink wire is for the ignition it should be going back to the fuse panel. I believe your brown wire is actually tan with 2 white stripes is for the brake light. If they are out of the harness there is a schematic for that on a previous forum. But it should be from left to right in the harness grey, tan, blue with white stripes, tan with white stripes, pink, beige, dark green. Hope this helps.
Old Mar 24, 2014 | 04:38 PM
Cortez1888's Avatar
Ive posted pics of the wires, or trying for the first time to lol. I dont have any other electrical issues other than my gauge lights. So im curious if they have something to do with my gauge lights not working, or could one be for the radio?
Old Mar 24, 2014 | 04:43 PM
Cortez1888's Avatar
Ive also changed the fuse in the panel and cleaned with a wire brush. I changed the gen bulb out to see if it was blown, still nothing.
Old Mar 25, 2014 | 01:42 PM
So you are saying that you have no lights in one pod only, correct? Are the illumination lamps in that pod also not working, or just the idiot lights? If the idiot lights AND the illumination lights are all non-functional, it's definitely a ground problem. These pods are grounded with a metal strap that runs from one of the mounting bolts to the metal lower dash. If it's missing or not connected, that will cause the problems you have. Once again, trouble shoot before spending money on potentially unneeded parts like a sending unit.
Old Mar 25, 2014 | 04:02 PM
From the pics I don't think they have anything to do with your problem I had this problem with my 69 and it was just a crappy ground. Honestly that's always a good place to start I have been driven nuts over something as simple as that before so before throwing money away check it out.
Markwz11
Apr 4, 2014 02:29 PM
kansasculass
Dec 9, 2011 06:11 AM
Nails
Sep 7, 2011 03:30 PM
Kidcutty
Feb 10, 2011 09:05 AM
silverriff
Feb 13, 2008 03:59 PM
