68 442 How do I know what signal switch I need to order?
The are no marking on mine other than a date. I need to order one and it looks like there was a Delco and a BPM but I can't find anything specific that tells what to order. Its for a 4speed non tilt. Here is a pic if it helps at all.
P__1400.jpg?t=1358133808
IIRC "most" Delco units were white plastic and Boyne was blue plastic.
Rock auto may have what you need:
Electrical-Switch & Relay : Turn Signal SwitchRelated PartsOE PRO Part # SM211
w/o tilt wheel; w/o cornering lights; Delco - white cam$46.79$46.79
Electrical-Switch & Relay : Turn Signal SwitchRelated PartsOE PRO Part # SM211 w/o tilt wheel; w/o cornering lights; Delco - white cam$46.79$46.79
I'm willing to bet that the two designs are interchangeable. Consider that there was only one upper steering column housing that they bolted into, only one dash harness that they connect to, only one turn signal lever (yeah, cruise and non-cruise, but you know what I mean), and only one cancel cam. If there was a functional or dimensional difference between the two, these parts would likely need to change to match.
ominayak83
Apr 18, 2013 10:55 AM
dennisspeaks
Oct 1, 2011 06:02 PM
