68 442 front courtesy harness?
Putting the courtesy light harness in...I hope you can see the picture. Question is... there is a single white wire connector in the middle of the harness...what does this connect to? There is the double connector with a white and orange wire and the connection was obvious there to the instrument harness. Then the connector that goes to the fuse block...does it go to the Accsy blade at the top? or the Battery blade below(powered all the time I assume).
Tom
68 442 Convt
70 F85
95 Aurora
Tom
68 442 Convt
70 F85
95 Aurora
Looks like the orange wire is to the front of the fuse block (upper right of the "batt" word on the block). The single white wire is always an open ground connection (doors, main lamp, or map light) in the 68 courtesy harnesses. I don't know if that answers your question, but the orange is hot all the time. I thought I sent you a high rez pic of this, if you still need one let me know
