67 442 fuel gauge won’t drop
My fuel gauge won’t go down. Unplugged sender and no difference. Even took the gauge out of the dash it stays where it was. If I manually push the needle back to empty and turn the ignition on it does go to how much fuel I have.
bad gauge?
bad gauge?
Hook everything back up, disconnect and ground the wire that runs from the gauge to the fuel sending unit with the key on. It should go to E then leave that wire not connected (open) the gauge should read past F
