67 442 fuel gauge won’t drop
Old Jun 18, 2021 | 10:59 AM
NotDads442's Avatar
My fuel gauge won’t go down. Unplugged sender and no difference. Even took the gauge out of the dash it stays where it was. If I manually push the needle back to empty and turn the ignition on it does go to how much fuel I have.
bad gauge?
Old Jun 18, 2021 | 11:26 AM
Sounds like it. You should be able to bench test it and make it go from E to F with the appropriate grounding and 12V.
Old Jun 18, 2021 | 01:45 PM
Hook everything back up, disconnect and ground the wire that runs from the gauge to the fuel sending unit with the key on. It should go to E then leave that wire not connected (open) the gauge should read past F
Cruiser Bob
Jun 21, 2019 10:07 AM
Neil F85
Jun 16, 2019 08:48 AM
69350rocket
May 11, 2015 11:48 AM
lemoldsnut
Aug 20, 2013 09:32 PM
ozzyolds
Aug 13, 2008 11:11 AM
