66-67 dash harness ID
Old Feb 25, 2023 | 06:36 AM
omy442's Avatar
Continuing to sort 66-67 parts collection.
Spaghetti.... dash harnesses time.
I have several fuse block panel harnesses. Some are attached to dash assemblies and several are loose.
​​​​​​I see fuse box for 66-67 is different than 68-72.
So I can ID based on fuse box style.
Pic below seems to be for a standard trans for it has a lead wire (green) for backup switch that's similar to my 68.
Do 66-67 dash harness have similar lead wires to accessories like auto floor console similar to 68-69?
​​​​​​Thanks
Mader
jm68442@yahoo.com
Old Feb 25, 2023 | 06:50 AM
The two wire green extension is the jumper harness for the backup light switch on an MT car. I can't tell if the NSS connector with the two purple wires has the jumper in it or not. The 66-67 cars didn't use a clutch safety switch, just a jumper (the assumption being that drivers of MT cars knew to press the clutch pedal before trying to start the car).
ros6872
Dec 9, 2024 02:40 AM
NotDads442
May 9, 2021 06:06 PM
Tiberian Fiend
Jul 26, 2018 11:37 AM
jwr7042
Aug 17, 2016 06:22 AM
jugdish
Jun 22, 2010 03:29 AM
