55 Olds 88 Coupe
Old Dec 13, 2006 | 10:41 AM
troberts6
Guest
Posts: n/a
Question 55 Olds 88 Coupe
How do i take the horn ring off of the steering wheel? I need to figure out what my problem is with the horns. Also where could i get a set of new horns?
Thanks,
todd
Old Dec 13, 2006 | 11:48 AM
Oldsguy's Avatar
Past Administrator
Welcome to our site Todd.
So, you are sure that the horn switch in the steering wheel is it right? If not, you are doing something you really don't need to do until you have made sure the horns themselves work and the wiring is good.
Old Dec 13, 2006 | 12:39 PM
troberts6
Guest
Posts: n/a
thank you, when you test the horn with battery, do you only touch the positive sides? some guy told me that earlier, but that doesnt make any sense.
Old Dec 13, 2006 | 02:44 PM
texasred's Avatar
Tom Servo's Stunt Double
The horns are grounded through the mounts to the body. Run a wire from the battery to the electrical connector on the horn.
C.J.
Gearhead442
Sep 6, 2023 05:30 PM
RTTOY
17
Nov 15, 2020 12:09 PM
coldfire
Aug 13, 2019 08:08 PM
1970w30
May 24, 2011 07:31 PM
oils66
Nov 25, 2009 08:25 AM
