1986 Buick Regal a/c power
Old Dec 5, 2021 | 01:29 PM
Slowpoke's Avatar
Hello all I have a 86 Buick Regal and recently removed the factory ecu , ecu harness and c.c carburetor and replaced it all with a Holley sniper ecu. What do I need to do to get the power back to the a/c ? Any help is much appreciated
Old Dec 13, 2021 | 09:54 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Get a wiring manual, it helps. The Cruise and A/C relay I believe is grounded through the ECM. Just find and ground to the body. The Cruise is the black wire off the speed sensor.
Old Dec 13, 2021 | 10:16 AM
Slowpoke's Avatar
Thank you for the response! Since I posted this I figured it out. The answer is the brown wire coming from the compressor relay mounted on the air box is the wire that needs to be grounded to turn on the compressor.
Old Dec 13, 2021 | 11:23 AM
I just saw this, glad you found it.
Old Dec 13, 2021 | 01:11 PM
Slowpoke's Avatar
i just saw this, glad you found it.
Jan Smolders
Apr 25, 2020 07:53 AM
extreme_442
Oct 1, 2019 06:32 PM
Olds luvr
Mar 19, 2015 09:34 AM
ralsy
Jun 30, 2012 04:22 PM
pearldawg23
Feb 14, 2008 05:08 AM
