1971 cutlass speedo lights
Old Sep 27, 2021 | 06:42 AM
ssx2james's Avatar
my right blinker indicator stopped working, but the the front and rear signals came on just didnt think they did. i replaced bulbs behind speedo but now both signal lights also speedo light out. do i have to reattach bezel for it to work because of the ground.also i noticed 1 of the 5 bulb housings is dark gray and the other 4 are light gray. does the darker 1 go back in the top center, didnt pay attention when i removed thank you
Old Sep 27, 2021 | 08:25 AM
70sgeek's Avatar
'72 Cutlass ragtop
Try reversing the bulbs in their housing to see if flipping the contacts around gets them to light. The gauge cluster should be re-bolted to the dash to ground it but the actual cover bezel itself doesn't have to be reinstalled.
next if no better result and assuming your circuit board isn't suspect for being bad, try new bulbs and/or bulb housings
If I recall, the different color housings only delineated the bulbs being used in them (if anything at all) - i.e. 168 v. 194 bulbs. In practice I don't know that it makes a real difference which of them you use except for one supposedly being a little brighter than the other. I use all LED's in mine with the 194 designation.
Old Sep 27, 2021 | 12:27 PM
Schne442's Avatar
No it's not a parts car!!
I was just working on my Dash lights yesterday(72 Cutlass) the Speedometer bulb sockets are 4 gray and one black
the black one is for the High beam indicator
on the bulb socket make sure you slightly bend out the tabs so they make solid contact on the housing circuit board
Old Sep 27, 2021 | 05:14 PM
PatL's Avatar
The housing color doesn't really matter as far as the bulb lighting up, but as Schne442 pointed out, make sure the contacts on contacting the circuit board. I have seen some of the replacement ones out there not doing that.
Old Sep 30, 2021 | 07:34 PM
ssx2james's Avatar
reattached gauge and turned bulbs around and now they work. thanks for the help
Old Oct 1, 2021 | 06:49 AM
PatL's Avatar
were you putting in LED bulbs?
Old Oct 2, 2021 | 04:30 AM
ssx2james's Avatar
no, was just wanting to get the signal indicators to work
NoVA_69_442
Apr 14, 2020 01:49 PM
My2nd 69 442
Apr 24, 2018 06:49 PM
1971viking
Aug 9, 2012 07:25 PM
raatj011
Jul 31, 2012 06:27 AM
Mattia-SS
Jun 30, 2011 05:22 PM
