1970 Cutlass fuel gauge issue
Old May 13, 2021 | 04:11 PM
wherlehy's Avatar
Angry 1970 Cutlass fuel gauge issue
Resurrecting an old thread here. First, installing ttt gauges replacing existing dummy light gauge.
1. Fuel reading worked on the old dummy gauge.
2. Right now the fuel reading is pegged past Full
3. I grounded the fuel wire inside the trunk to the gauge and Fuel reading pegged past empty. This test should tell me the circuit to the gauge is fine - correct?
Couldn't I run a wire from the sending unit connector in the trunk to the gauge and get a reading?
Help.
Old May 13, 2021 | 04:56 PM
jaunty75's Avatar
Yes.
Yes, but you wouldn't solve the problem because you just demonstrated that the wire that now runs from the gauge to the rear of the car is ok because the gauge went to E. So you'd just be replacing one good wire with another one.
Your test demonstrated that the problem is in the REAR of the car. The fact that it pegs past full says open circuit. Could be a bad connection from the sending unit to ground, a broken wire from the connector at the rear of the car to the sending unit, or a bad sending unit.
Old May 13, 2021 | 06:06 PM
wherlehy's Avatar
Thank you Jaunty for your fast response!
I will check the connections in the trunk in the next few days.
Old May 15, 2021 | 05:32 PM
wherlehy's Avatar
I crawled underneath the car and the ground connection looks good. After driving the car for to burn gas (it was initially full) to see if the gauge would move. The gauge moved an 1/8 of a tank but I know it should be at half full or lower with the giant four-barrel I have on the car.
So this seems to state I have sending unit issue - agree? What's frustrating is I removed the old gauge, which was working, and when I install the ttt rally gauge - it doesn't work.
Thanks!
Old May 15, 2021 | 07:20 PM
jaunty75's Avatar
Yes, I agree that things are point to a sending-unit problem.
smparr
Nov 6, 2021 07:53 PM
Cruiser Bob
Jun 21, 2019 10:07 AM
68442w30
Jan 1, 2019 02:11 PM
57droptop
Aug 27, 2018 06:20 PM
abrasv
Jul 21, 2018 04:20 AM
