Fuel gauge
Old Jan 1, 2019 | 10:45 AM
68442w30's Avatar
Fuel gauge
Anyone know the in"s and out's of the fuel gauge electrical system for the 1968 442"s
Old Jan 1, 2019 | 11:44 AM
Yes, whats your problem?
Old Jan 1, 2019 | 12:26 PM
68442w30's Avatar
Hey thanks for the reply,
I cut the fuel gauge wire at the top of the tank just before it reaches the opening of the pick up .
I spliced it back together with a side by side wire connector but still no voltage before or after the block connector in the trunk.
what am I missing
Old Jan 1, 2019 | 12:57 PM
There will not be any voltage there unless its open. The float works off of the ground side. Is your gauge working with the key on?
Old Jan 1, 2019 | 01:19 PM
68442w30's Avatar
Yes
as soon as I turn the key on it pins to full (F)
I checked the ground and its solid
this happened after I cut it and spliced it back
Old Jan 1, 2019 | 02:09 PM
Ground that wire with the key on, the gauge should go to E. If it does, check your work or the ground to your fuel sender is no good, or the sender itself..
Old Jan 1, 2019 | 02:11 PM
68442w30's Avatar
ill do
thanks
Cruiser Bob
Jun 21, 2019 10:07 AM
57droptop
Aug 27, 2018 06:20 PM
fun2sun
Apr 18, 2016 08:25 PM
jgjb39
Nov 13, 2014 02:15 PM
Darin Matera
Nov 12, 2014 07:04 PM
