Fuel gauge
Old January 1st, 2019, 10:45 AM
68442w30's Avatar
Fuel gauge
Anyone know the in"s and out's of the fuel gauge electrical system for the 1968 442"s
68442w30 is offline
Old January 1st, 2019, 11:44 AM
Yes, whats your problem?
oldcutlass is online now
Old January 1st, 2019, 12:26 PM
68442w30's Avatar
Hey thanks for the reply,
I cut the fuel gauge wire at the top of the tank just before it reaches the opening of the pick up .
I spliced it back together with a side by side wire connector but still no voltage before or after the block connector in the trunk.
what am I missing
68442w30 is offline
Old January 1st, 2019, 12:57 PM
There will not be any voltage there unless its open. The float works off of the ground side. Is your gauge working with the key on?
Old January 1st, 2019, 01:19 PM
68442w30's Avatar
Yes
as soon as I turn the key on it pins to full (F)
I checked the ground and its solid
this happened after I cut it and spliced it back
68442w30 is offline
Old January 1st, 2019, 02:09 PM
Ground that wire with the key on, the gauge should go to E. If it does, check your work or the ground to your fuel sender is no good, or the sender itself..
Old January 1st, 2019, 02:11 PM
68442w30's Avatar
ill do
thanks
68442w30 is offline
Cruiser Bob
June 21st, 2019 10:07 AM
57droptop
August 27th, 2018 06:20 PM
fun2sun
April 18th, 2016 08:25 PM
jgjb39
November 13th, 2014 02:15 PM
Darin Matera
November 12th, 2014 07:04 PM
Quick Reply: Fuel gauge
