1970 442 Alternator charge Wire
Old Dec 28, 2025 | 09:33 PM
70_455's Avatar
Hello
Would anyine know the routing path and the actual length of the alternator wire ( From end of ring to end of ring) that goes to the horn relay?.. I know the one on there isnt correct so id like to make a new one.
Thanks!
Old Dec 29, 2025 | 02:02 AM
A/C or non-A/C, since the alternators are in different places?
Old Dec 29, 2025 | 06:30 AM
70_455's Avatar
Didnt know that either...but It has AC.
Old Dec 29, 2025 | 09:38 AM
Alternator is on the driver side with A/C and on the passenger side without.
Old Dec 29, 2025 | 10:13 AM
70_455's Avatar
I always learn something new on these boards!..
Old Dec 30, 2025 | 07:41 AM
70_455's Avatar
If no one knows the length of the wire, would anyone have a picture of the correct routing?
Old Dec 30, 2025 | 08:54 AM
Section 12, Page 166 in the PIM. Upper RH image.
Old Dec 30, 2025 | 09:23 AM
70_455's Avatar
Thanks for the picture of the layout..
I assume that is a picture of an externally regulated model because of the connector location on back?
It looks like a taped harness.. Is the charging wire in that loom just for cable managrment? Meaning individual wire straight from the post on alternator to the horn relay?
Old Dec 30, 2025 | 09:32 AM
Yes, the wire runs directly from the BAT post on the alternator to the horn relay. The harness is wrapped with plastic tape (non-adhesive) to simplify installation on the assembly line.
Old Dec 30, 2025 | 02:59 PM
70_455's Avatar
Joe
If i decide to change the engine and headlight harnesses, does that cover most of the engine compartment besides the A/C?
Old Jan 1, 2026 | 07:25 AM
The engine and forward lamp harnesses cover all base equipment functions in the engine compartment. The HVAC harness is separate, and obviously power accessories have their own dedicated harnesses.
Mikeyt
Aug 20, 2024 07:43 PM
ostie13
Aug 28, 2014 08:33 AM
joepenoso
Jun 28, 2013 01:11 PM
lonestarjarhead
Mar 20, 2013 07:52 AM
Joel
Apr 12, 2011 02:58 AM
