1970 442 Alternator charge Wire
Hello
Would anyine know the routing path and the actual length of the alternator wire ( From end of ring to end of ring) that goes to the horn relay?.. I know the one on there isnt correct so id like to make a new one.
Thanks!
Thanks!
Thanks for the picture of the layout..
I assume that is a picture of an externally regulated model because of the connector location on back?
It looks like a taped harness.. Is the charging wire in that loom just for cable managrment? Meaning individual wire straight from the post on alternator to the horn relay?
