1969 442 Distributor P-Tronics
Old Jun 13, 2025 | 05:09 PM
442b's Avatar
So, we replaced the points and condenser in my 1969 442 400c.i. with P-Tronics Electronics. Now it runs like crap, like the timing is off or something. Hard to explain. My nephew /mechanic said we should change it over. Any experience with P-Tronics issues when replacing original points and condenser system? Thanks
Old Jun 13, 2025 | 07:52 PM
Which Pertronix unit did you install? Did you reset the timing after the install? Is it wired with 12v to the module and the resistance wire to the coil?
Old Jun 13, 2025 | 09:07 PM
redoldsman's Avatar
Proud Viet Nam Veteran
My experience with Pertronix is that it left me on the side of the road when I had my 54. I went back to quality Delco points and condenser. I found the old NOS kind made in the USA on ebay. I would through the Pertronix in the trash. Of course you don't want to do that after you spent money on the conversion. Go back and read the instructions and make sure everything is installed correctly. When they are working, they are fine.
Old Jun 14, 2025 | 04:13 AM
442b's Avatar
Installed this "Pertronix Ignition Conversion Kit | 1181" Yes as far as I know to your other questions, but I'll find out for sure today.
Old Jun 14, 2025 | 11:27 AM
442b's Avatar
Update - removed p-tronics and reinstalled pionts and condensor, run great once again. It has been a learning expericence for sure. - case closed
MPSax
Feb 20, 2024 08:54 PM
ericisback
May 31, 2023 06:49 AM
1k442
Nov 21, 2017 05:02 PM
70-Olds-442-convt
Jan 16, 2017 09:32 AM
smietana
Aug 3, 2014 12:10 PM
