1967 Olds 98 wiring digram (convertible top)
Old Jun 24, 2008 | 07:16 AM
WAYNEWATSON's Avatar
Looking for a wiring diagram for a 1967 Olds Ninety Eight, for the convertible top. We have one that is not working and is electrical related.
waynewatson@comcast.net
651-578-1500 W
651-578-1515 Fax
Old Nov 12, 2021 | 10:56 AM
tank_ford's Avatar
Did you ever find this? I'm in need of it
Old Nov 12, 2021 | 11:30 AM
This post is 13 years old, the OP posted once 13 years ago and has not posted since. So, an answer from the OP is highly unlikely. With that said, another CO member may find your question and find a diagram for you. If you want a 1967 Olds Ninety Eight convertible top wiring diagram, I believe it is contained in the PIM or the Fisher Body Manual. I don't have either of these. WildAboutCarsOnline may have a copy of the PIM and I believe there is another CO member who has shared out some PIM and/or Fisher Body Manuals. You might perform some searches for convertible top wiring diagrams. Good luck!
Old Nov 12, 2021 | 11:31 AM
tank_ford's Avatar
Thank You
Old Nov 12, 2021 | 11:39 AM
The only PIM I see for the 1967 year on WildAboutCarsOnline is for the 1967 A-Body models - nothing for a 98. Others may know if it may have been included in the CSM, but most years the convertible top wiring was stuck in either the PIM or the Fisher Body Manual - I can't recall which.
Old Nov 12, 2021 | 11:42 AM
tank_ford's Avatar
I have a 1968 98. I really need the diagram for ignition wires
Old Nov 12, 2021 | 11:43 AM
Well, there are two .pdf files for the 1967 production year on WildAboutCarsOnline for Fisher Body Service Manuals. I'll have a quick look to see if anything pops up.
1967 Fisher Body Service Manual - Section 16: Electrical: pgs 16-1 thru 16-33
1967_Fisher_Body_Service_Manual_Section_16A.pdf
1967 Fisher Body Service Manual - Section 16: Electrical: pgs 16-34 thru 16-65
1967_Fisher_Body_Service_Manual_Section_16B.pdf
Old Nov 12, 2021 | 11:46 AM
Which wiring diagram is it you need 1967 98 or 1968 98? I thought you were looking for the convertible wiring diagram but I guess that's just because you found a thread regarding 1967 wiring diagram. OK. Let me see.
Old Nov 12, 2021 | 11:48 AM
tank_ford's Avatar
Yes I need 1968 Olds 98 wiring diagram for ignition. Was trying to install a pust button start on it
Old Nov 12, 2021 | 11:51 AM
So, I don't have time at the moment to review the specific wiring diagrams, but there are two sections of wiring diagrams for the 1968 production year which includes all models. To d/l the diagrams requires a membership to WildAboutCarsOnline (which I have), but I don't have the time as said to find which diagram you need for ignition. The membership is not expensive.
1968 Fisher Body Service Manual - Section 16: Electrical: pgs 16-1 thru 16-27
1968_Fisher_Body_SM_Sect_16.1.pdf
1968 Fisher Body Service Manual - Section 16: Electrical: pgs 16-28 thru 16-57
1968_Fisher_Body_SM_Sect_16.2.pdf
Old Nov 12, 2021 | 01:56 PM
67OAI's Avatar
Old(s)GuysRule
The wiring diagram should be found in the chassis service manual, CSM, for that year I would think.
Sid
Jan 25, 2015 12:59 PM
ros6872
Mar 16, 2012 01:09 PM
ros6872
Nov 26, 2011 11:00 AM
ros6872
Oct 27, 2011 11:39 AM
Eddie Hansen
Dec 24, 2009 10:51 AM
