1962 Starfire Alternator Wiring
Old Sep 3, 2012 | 08:29 PM
stevenstarkweather's Avatar
Hello Folks,
To trouble shoot a short in my dash wiring I have removed all connections at the horn relay – the positive battery lead, the starter, the Holley fuel pump – and reading the voltmeter at the 20v setting across the negative battery post and the grounding frame strap. The starter reads .02v. Add the pump, .05. Everything is clean to that point. But when I attach the alternator to the horn relay, it reads full voltage equivalent to the battery charge.
The alternator is rebuilt, double bench tested and wired per other posts on replacing a generator with an S10 (see attached, thanks Joe P). Is this the correct way to test an alternator?
Steven
Old Sep 9, 2012 | 09:04 PM
Anyone? I really don't want to just crank it up and see if it smokes.
Old Sep 10, 2012 | 04:06 AM
stellar's Avatar
stellar
The wiring looks correct, but the test shows a shorted alt. Is there a spark when the bat cable it touched to the bat terminal.
Old Sep 10, 2012 | 06:53 AM
It will read full battery voltage at the horn relay because it's looking for a ground from your horn contact behind the steering wheel to make the horn operate.
6inarow
Aug 27, 2019 11:22 AM
442mark
Sep 30, 2017 01:06 PM
stevenstarkweather
Nov 2, 2012 04:18 PM
eddieunderground
Aug 1, 2012 02:41 AM
eddieunderground
May 13, 2012 10:34 PM
