1961 88 Fuel Sender wiring routing
Hi guys! I dropped my tank today to clean it and look at the fuel sender. It seems the wiring is no longer existent. Where did the factory route the wiring for this to the front?
The fuel guage harness connects to the main harness that connects the fuse block to the tail lights, .
This connection is up inside the trunk near the rear axle . the fuel sender harness goes through a rubber grommet in this area to the tank sender .
The fuel sender harness contains two wires that connect to the sender . They are yellow and gray .
Both the yellow and gray wires connect to the sender with the little push on connectors shown .
The remnants of the one connector you have should give you a clue as to which wires connect where .
oldsvista_65
March 15th, 2017 10:45 AM
