1957 dash cluster
Old Jan 14, 2019 | 04:42 PM
supmarjo's Avatar
Exclamation 1957 dash cluster
electric issue or bad starter switch.. Im trying to figure out how this wire circuit works.
I did continuity test on the switch and it dose not make contact to any other post or ground .
I bought a new temp sender.. my cold and hot lights where working before started re wiring the engine bay.
Old Jan 15, 2019 | 01:43 PM
danktx's Avatar
That wire is what causes the hot light to illuminate when the key is in the start position as a test to show that the bulb is working. Circuit continuity only occurs when the key is in the crank position.
Old Jan 15, 2019 | 07:12 PM
supmarjo's Avatar
Exclamation
thanks, danktx , aww i do remember when cranking motor it illuminate then off after starting.
i have not install the new sender, buy did a continuity test the new. one only shows continuity between the body and one prong, will that one be the ‘hot’ lead .
i have the car in storage and will try and get to it tomorrow ..a lot of rain here in calif.
continuity test, pic
Old Jan 15, 2019 | 07:31 PM
The one that shows continuity I would assume to be the cold lamp.
Old Jan 16, 2019 | 05:17 PM
supmarjo's Avatar
Smile
YES! everything back to the way it was .... had a bad sender and I hooked it up wrong.
Seamed to be ez but just over looked the install .
THANKS guys for the help.
here pic of new wheels n tires .... hoping to get going soon
Old Jan 16, 2019 | 07:05 PM
Sweet look
Eightbanger
May 14, 2016 08:20 PM
Chris289
Mar 27, 2015 05:55 AM
TomOD
Oct 27, 2013 11:47 AM
oldsmobum
Nov 7, 2011 04:39 PM
mauls
Feb 17, 2011 12:36 PM
