Shim a power steering pump?
Old May 1, 2014 | 03:35 AM
blakes7's Avatar
Anyone ever have to shim a power steering pump? I just replaced mine, and the angle is a little off, which will probably shorten the life of the belts. This is the first time I've come across this, has anyone ever had to shim a power steering pump? Thanks.
Old May 1, 2014 | 03:48 AM
You have both of the power steering pump bracket spacers in the proper locations, right?
Old May 1, 2014 | 03:30 PM
blakes7's Avatar
I'll check, it was 2 weeks between when I took it apart and put it all back together. The link you posted will be helpful. Thank you.
Old May 1, 2014 | 04:15 PM
Rocketguy's Avatar
What year and model Oldsmobile are you working on?
A/C?
Stock set up?
Old May 1, 2014 | 07:26 PM
blakes7's Avatar
71 Delta 88 455 with air.
Old May 2, 2014 | 06:45 AM
The bottom line is that shims were not required before you took it apart, and have never been used by the factory, so I'm willing to bet that it is not assembled correctly. As Eric noted, the most common cause of PS belt alignment posts is missing factory spacers. I'll go even further and suggest that it's the lower one, that goes between the bottom bracket and the side of the block. These fall out during disassembly and get overlooked. It's likely on the floor of your garage someplace.
Old May 2, 2014 | 08:09 PM
blakes7's Avatar
I plan to show it to a few knowledgeable people I know this weekend, and at big Olds show on Sun. I think I have that spacer, and put it in the wrong place. It's now a matter of having the time to get in there and put it in the right place. Thank you all for your advice.
Old May 3, 2014 | 10:18 AM
Or, you could just use the SEARCH function...
Old May 3, 2014 | 11:35 AM
No need to, since I linked to the thread which contains the following illustration (which you posted) in my first response to him:
Old May 3, 2014 | 09:58 PM
blakes7's Avatar
Thanks again for the info and diagrams, they will be very helpful when I get to repairing this. Thank you all very much.
Macadoo
Dec 9, 2013 06:23 PM
joepenoso
May 22, 2013 08:38 PM
68442
Apr 1, 2013 08:16 PM
sammy
Jan 29, 2013 03:21 PM
pavemobile
Oct 8, 2012 06:15 PM
