Wiring up a new voltage regulator on my '63
I got a new BWD select voltage regulator for my '63 Super. Looks entirely different. 4 connectors across the bottom. My original has three leads going to it: purple, black and red.
Anyone know how to hook this up?
Yup.
The problem is that you have the wrong regulator.
'63 had a one-year-only setup that had a separate voltage regulator (three terminals) and warning-light relay.
The following year they put the two components together into the four-wire regulator that was used for years after.
You can redirect the wiring to work with the newer regulator, as shown in the diagrams here (reposted below), by using the (+), Field, Light, and R wires, and capping off the green wire to the ACC circuit and the extra Red (+) wire.
Alternatively, you could return your regulator and search for the (more rare and expensive, one-year-only) regulator that your car came with.
Did yours look like this one?
http://www.autopartswarehouse.com/de...2QQSIVR30.html
Okay guys - I checked the other thread where the diagrams came from and have one problem. My light relay only has 2 leads - green and black. My voltage regulator has purple red and brown.
My voltage regulator has F 2 3 4. From the diagram looks like
2 - Purple
3 - Red
4 - Brown
Green gets capped off and Black goes to F
Right?
2 - Purple
3 - Red
4 - Brown
Right?
The relay circled in yellow is the alternator warning light relay.
The relay next to it, with the main power stud on it, is the horn relay.
Your voltage regulator (three-wire) should be on the firewall near the center.
The light relay and the regulator are next to each other in the schematic, but not in real life.
If you've already got a four-wire regulator, then someone else probably rewired it and the warning light relay isn't being used, as it is incorporated inside of the four-wire relay.
Maybe really close photographs of all of these parts and their wires are in order.
Just be sure to look at the schematic and run through the wires to make sure that everything's hooked up right - when "the other guy" rewires the car, you never know what he could have done.
And make sure everything is soldered - no twists, crimps, or () wire nute!
delta_88_germany
February 22nd, 2014 01:48 PM
