Broken accellerator (gas) pedal
Old Jul 4, 2011 | 06:00 PM
Mak's Avatar
Mak
Hello all, The sockets on my accel pedal are broken, so it doesn't snap onto the ***** and stay in place well. Seems to fall off at very inopportune times (stop and go traffic an a very steep hill in SF, lol). Anyone know where to get a replacement pedal for a 67 Delta 88 for a reasonable price?
Old Jul 4, 2011 | 06:13 PM
You mean the bellcrank ends and sockets that connect the linkage from the pedal to the carb?
Yours may just be frozen with rust and dried grease - I'd try soaking them in lacquer thinner overnight and giving them a good cleaning, then maybe a bit of penetrating oil.
If the springs (round clips) are stuck in their grooves, they may release and grip again.
Otherwise, they're actually a standard hardware item - shouldn't be hard to find at a GOOD local hardware store or on line.
Old Jul 4, 2011 | 06:17 PM
Mak's Avatar
Mak
No, sorry, I mean the pivot ***** that hold the pedal to the floor... from looking at it I'm pretty sure I'm gonna need a new pedal.
Old Jul 4, 2011 | 07:48 PM
Rickman48's Avatar
Clean the area around the pivot ***** real well with a wire brush, trimming the carpet as necessary, and vacuum.
If necessary, I believe The Parts Place has replacement pedals reasonably.
Old Jul 4, 2011 | 07:59 PM
Mak's Avatar
Mak
Yeah, cleaning won't help... the plastic (I assume) sockets on the pedal are completely broken. The parts place doesn't show Delta 88 as an option, but has gas pedals for cutlass/442 for $25... I wonder if they're the same pedal?
Old Jul 5, 2011 | 05:33 AM
2blu442's Avatar
The Cutlass pedal is smaller, so I suspect the distance between the posts would be different. I do have a used one that's not too bad. Work is busy right now but I'll try to get some pictures/measurements for you later this week. John
Old Jul 5, 2011 | 07:16 AM
Tedd Thompson's Avatar
You might try building up the socket with Shoe Goop, it is used to build up the soles of running shoes, sticks to most any kind of rubber,But of coarse new part would be better....Tedd
Old Jul 5, 2011 | 05:52 PM
Mak's Avatar
Mak
Cool... If it's the right size I'd be interested.
slowolds
Jul 21, 2010 02:31 AM
Gaz Hog
Jun 25, 2010 04:13 AM
My442
May 2, 2010 04:24 AM
jensenracing77
Feb 7, 2010 05:30 AM
64starfire
Jun 12, 2009 07:43 AM
