Vin #
Old Nov 25, 2010 | 08:41 AM
coldguy02's Avatar
Vin #
Hello I trying to find the vin# on my car I think its a 63 oldsmobile dynamic 88 i cant find the vin location. any help would be great thanks.
Old Nov 25, 2010 | 10:45 AM
Rickman48's Avatar
When you open the drivers door, it shoud be inside, on the cowl, above the hinges.
I've only seen them above that, on the drivers roof piller, on tri-5 chevys.
If you see evidence of 2 rivets, it probably fell off - the rivets corrode!!
Old Dec 8, 2010 | 04:15 AM
OLDZGUY's Avatar
Talking 1963 Full Size & F-85 VIN, Engine, Trans & Rear Axle info
*Vehicle Identification Number is on Left Front Door Pillar for 1963
1st 2 numbers = year
3rd number is Series: 0=F-85 Standard 30 series/ 1= F-85 Deluxe 31 series/ 2= 88 32 series/ 5= Super 88 35 series/ 6= Starfire 36 series/ 8= 98 38 series/ 9= 98 series
4th is LETTER for Assembly Plant: M= Lansing, MI/ A= Atlanta, GA/ K= Kansas City, KS/ L= Linden, NJ/ C= South Gate, CA/ W= Wilmington, DE/ T= Arlington, TX
Following Numbers are Vehicle Unit Number
*ENGINE Unit Number for Full Size Olds is Stamped on Left Cylinder Head
F-85 Series is Stamped on Front of Right Cylinder Head
*Full Size Olds Hydra-Matic TRANS is attached to Left Side of Trans Case (L after Ratio Number Anti-Spin)
O on Black Plate: 2BC Lo Comp & Export 32 series
OC on Aluminum Plate: 2BC Std Comp 32 series
OA on Dark Brown Plate: 4BC Std Comp 32, 35 & 38 series
OB on Yellow Plate: 4BC Std Comp 36 & 39 series
OCH on Taffy Tan Plate is HD: 2 & 4BC All Except 36 & 39 series
*F-85 HYDRA-MATIC TRANS Serial Number Plate is on Right Side Trans Case
O on Dark Green Plate: 2BC Steering Column Shift (SCS) 30 & 31 series
OD on Red Plate: 4BC (SCS) 31 series
OE on Pink Plate: 4BC Console Shift (CS) 31 series
OX on Aluminum Plate: Turbo-Rocket (CS) 3147 series
*REAR AXLE RATIOS
Full Size Olds Axle Number: Stamped on Carrier Casing Lower Indicating Boss
Code 2 43:16 (2.69:1)
Code 3 41:16 (2.56:1)
Code 7 43:15 (2.87:1)
Code 8 41:12 ( 3.42:1)
Code 9 42:13 (3.23:1)
Code 0 40:13 (3.06:1)
F-85 Series Olds Axle Ratio & Date Code: Stamped on Right Side of Housing Cover ( O with X inside after Date Code is Anti-Spin) Number after Code is Day of Year Built
A 40:13 (3.08:1)
B 42:13 (3.23:1)
C 37:11 ( 3.36:1)
Old Feb 1, 2012 | 11:40 AM
Carl's Avatar
how do I decode vin on a 1956 olds and will it tell me if it is a fourspeed hydromatic or the later jeteway
Old Feb 1, 2012 | 12:30 PM
GAOldsman's Avatar
"Car"mudgeon
1946 - 1997 Olds VIN # decoder here
http://v8cars.hu/oldsvin/decode.php
And no it won't tell you trans or engine data, just year, make, model, plant and serial #
Cowl tag will tell you a bit more such as body & interior color(s) and style then an accessory or two.
Don Bunnell
May 8, 2020 02:15 PM
olds53rocket
Dec 22, 2006 05:46 PM
<thumbs60>
Nov 3, 2003 07:15 PM
<thumbs60>
Nov 3, 2003 07:06 PM
<Mr69442@aol.com>
Aug 17, 2002 03:55 PM
