55 door and trunk moldings vendors
Old March 31st, 2016, 09:50 AM
Fitti Fi's Avatar
Hi all, it's probably my lack of experience using the search engine here but I can't find what vendor would be the best for finding the door and trunk weatherstrip seal moldings for my 55 Super 88 4dr. sedan. I could use some guidance and thanks in advance.
Fitti Fi is offline
Old March 31st, 2016, 10:34 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Fusicks has them.
redoldsman is offline
Old March 31st, 2016, 12:03 PM
Fitti Fi's Avatar
Thanks redoldsman I'll check them out
Fitti Fi is offline
Old March 31st, 2016, 12:23 PM
redoldsman's Avatar
This is another one you might check out.
http://www.steelerubber.com/
Old March 31st, 2016, 03:40 PM
Rocketowner's Avatar
The ones that are on my 4 Dr. Holiday are from Steel Rubber Co. and the fit is good and are holding up well.I think Fusick's would be of good quality also. Good luck, Larry
Rocketowner is offline
Old April 1st, 2016, 05:21 AM
jozw30's Avatar
I recently bought everything from a website called "rubbertherightway.com". Most was in STEELE RUBBER packages. Everything installed nice except that the door pieces were about 7" too short. Think they'll fit the 4 door perfect. They sent a piece and I spliced it in at the bottom.
Another issue I had was the Steele Rubber trunk seal is soooooo stiff, I'm a month in and still can get my trunk lid to close nice. It's sitting on the highest adjustment and I can barely get it to close. Not sure what I'm going to if it doesn't settle down......
If you can find a trunk seal that is not from STEELE, get it. I usually only use Metro product, but they clearly don't see money to be made supporting these cars.
jozw30 is offline
Old April 1st, 2016, 10:06 AM
Fitti Fi's Avatar
Thanks for the info guys, I appreciate you taking the time to help out 👍🏻
Fitti Fi is offline
Old April 1st, 2016, 10:10 AM
redoldsman's Avatar
You are very welcome. That is what this place is all about, helping each other.
Old April 1st, 2016, 10:32 AM
Fitti Fi's Avatar
Amen to that.
Fitti Fi is offline
Old May 18th, 2016, 03:26 AM
aussie195588's Avatar
Late reply! But how did you with the trunk weatherstrip? I got one from fusick for my 55 and I cannot get the boot to shut? Seems to be too thick or something
Cheers
aussie195588 is offline
Old May 18th, 2016, 04:53 AM
jozw30's Avatar
Mine's been on there for a couple of months and it is still a pain to close. I am working on getting the car running so I'm just letting it compress with the lid closed. I think I may also need to move the lid rearward a tiny bit which may help.
All in all, pretty disappointed in that weatherstrip. Have replaced a bunch of these on different cars and never had this issue.
Good luck!
jozw30 is offline
Old May 18th, 2016, 02:58 PM
Thanks mate, I cant even get my trunk to shut? I have taken the rubber off already as I thought I put it on the wrong way.. I think I may go to a more generic weatherstrip as I already forked out $160 for this one
Cheers
Dan
Old May 18th, 2016, 07:11 PM
Tedd Thompson's Avatar
I believe I used a generic one on my 55. I got it off the shelf from Napa, worked fine.... Tedd
Tedd Thompson is offline
dnmfranco
September 13th, 2014 08:05 AM
redvettemike
December 20th, 2012 05:07 PM
1971 442 convert
May 9th, 2010 09:50 AM
ctrain22
October 18th, 2009 07:57 PM
68conv455
Site Suggestions
February 25th, 2009 08:11 PM
Quick Reply: 55 door and trunk moldings vendors
