windshield install ??
Old Jun 23, 2013 | 02:32 PM
willj's Avatar
i have a 65 b-body,starfire,was wondering if any one has put there own winshield in ,and if they used the spacer,s that are shown in the manuel.or if used just the butyle tape,and the two rubber spacer,s on the bottom that keep window from dropping, any help in this problem would really be appreciated , thanks will.
Old Jun 23, 2013 | 05:41 PM
Run to Rund's Avatar
The 3m kit comes with spacers. You need them, or the original ones, to hold the windshield from sliding down.
Old Jun 23, 2013 | 05:48 PM
willj's Avatar
window reply
i see the spacers for the bottom of windshield , but in manual it shows one on each side and 3 across the top and 3 across the bottom ,and one on each side , that go in btween the window and the pinch weld , any thought on tem , thank alot for your reply , will
Old Jun 23, 2013 | 07:14 PM
The first time I did an A-body windshield, I didn't use the spacers. The glass was too far to one side. I tried to force the stainless trim on...
I was a lot better on the second windshield.
Old Jun 24, 2013 | 01:19 PM
willj's Avatar
windshield ?
i thank you all for the replys , so am i understanding this right , that there is no need for any spacer,s that go under the windshield to keep it a certain distance from the pinchweld,that the 3 m kit will take care of that,i am missing something ,cause in my manual , it shows 9 or 10 spacers, any way , thank you for the help, will.
Old Jun 24, 2013 | 01:24 PM
No, you DO need the spacers. New ones come with the 3M kit. Use the new ones.
Old Jun 24, 2013 | 01:44 PM
willj's Avatar
window?
thanks again for the quick reply.will
woodie582
Feb 6, 2015 09:04 AM
frdmftr
Jun 28, 2007 01:33 PM
bigcaser
Dec 27, 2006 02:32 PM
HWYSTR455
Oct 16, 2006 10:03 AM
JoshF85
Mar 19, 2005 06:47 PM
