wheels and tires sizes 71-76
I'm looking at putting wider rear tires on my 76 delta 88. Anyone have any experence on what fits? width profile and backspacing? I'm willing to step up to a wider rim and or different backspacing, if neccesary but, would like to use a 15 inch steel rim so i can keep my stock hubcaps.
I'm currently restoring my '75 Olds Delta. I looked at many different sizes but also wanted to keep the wire wheel hubcaps. In the end, I went with 15x8 all the way round with 4" backstop. They fit nicely in the wells with no interference.
I am interested in doing the same thing. Could you post some pics Snowri so we can all get a visual. Thanks.
I believe Oldsguy had 255/75 R 15s on his 69 Delta 88. The good thing about a B body is that they don't have fender skirts in the back so you don't have to worry about tight spaces. Hopefully Oldsguy will post in a day or two.
Big Meats
I put 275/60/16's on all 4 corners of my 69 Delta. Fit great and look awesome. The wider tire fits the size of the car much better than the OEM 225's. I might have been able to go even bigger
I went with the Indy 500 Firestones on AR wheels and am very pleased.
To estimate fit and backspacing issues you may encounter, check out this site. I found it terrific to help me plan. http://www.rims-n-tires.com/rt_specs.jsp
Bigger Tires
I reread your note. If using original steel wheels make sure the new wider tires will fit on the wheel themselves. The OEM wheels are relatively narrow as I recall and will limit your choices as to how wide you can go with the new tires. Good luck and post back what you decide.
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
