wheels and tires sizes 71-76
Old Mar 24, 2009 | 09:31 AM
jaysun's Avatar
ate glue as a child
I'm looking at putting wider rear tires on my 76 delta 88. Anyone have any experence on what fits? width profile and backspacing? I'm willing to step up to a wider rim and or different backspacing, if neccesary but, would like to use a 15 inch steel rim so i can keep my stock hubcaps.
Old Mar 31, 2009 | 07:19 PM
snowri's Avatar
75_Delta
I'm currently restoring my '75 Olds Delta. I looked at many different sizes but also wanted to keep the wire wheel hubcaps. In the end, I went with 15x8 all the way round with 4" backstop. They fit nicely in the wells with no interference.
Old Apr 5, 2009 | 10:17 AM
ChrisM's Avatar
I am interested in doing the same thing. Could you post some pics Snowri so we can all get a visual. Thanks.
Old Apr 6, 2009 | 09:08 AM
jaysun's Avatar
ate glue as a child
Thanks Snowri, I'm guessing something like a 255/75r15 on the back?
Old Apr 6, 2009 | 01:58 PM
I believe Oldsguy had 255/75 R 15s on his 69 Delta 88. The good thing about a B body is that they don't have fender skirts in the back so you don't have to worry about tight spaces. Hopefully Oldsguy will post in a day or two.
Old Apr 9, 2009 | 08:48 AM
bcg88's Avatar
Big Meats
I put 275/60/16's on all 4 corners of my 69 Delta. Fit great and look awesome. The wider tire fits the size of the car much better than the OEM 225's. I might have been able to go even bigger
I went with the Indy 500 Firestones on AR wheels and am very pleased.
To estimate fit and backspacing issues you may encounter, check out this site. I found it terrific to help me plan. http://www.rims-n-tires.com/rt_specs.jsp
Old Apr 9, 2009 | 08:51 AM
bcg88's Avatar
Bigger Tires
I reread your note. If using original steel wheels make sure the new wider tires will fit on the wheel themselves. The OEM wheels are relatively narrow as I recall and will limit your choices as to how wide you can go with the new tires. Good luck and post back what you decide.
jnaarnold
Sep 12, 2017 08:09 PM
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
WTony
Jan 15, 2011 07:53 PM
ttg
Sep 14, 2008 03:15 PM
