what to look for while buying 1970 delta 88 convet.
Old Mar 11, 2009 | 06:53 PM
mahoneybags21's Avatar
what are some main things i should check. its got the 455, 12 bolt turbo 400 and 90k thats all i know so far
Old Mar 11, 2009 | 08:19 PM
dwsshay's Avatar
70 hulk
Talking
i have a 70 delta 88 convertible had 4 2 years now great car to look at and drive, real head turner make sure all trim parts are there very hard 2 find i almost got mine found but still looking 4 afew parts been fun looking but it is a great car would not trade 4 anything there getting harder 2 find,you will love it if you buy,goodluck
Old Mar 11, 2009 | 10:11 PM
old98owner's Avatar
With any of these big convertables look UNDER the car for rust in the floorboards. If an owner let the top get bad and water stood in the floors they can and will rust through. The floors in the back seat normally rust first.
Make sure the top is still secure where it is welded to the rear wheel well. These welds can break loose.
Make sure the doors close without having to lift up on them. This is rarely a problem, but if someone sat on an open door it could have bent the door or the body of the car where the door is bolted to it.
All of these are repairable and only the sprung door would cost a lot to repair. Other than that just take the care you would with any car this old.
If you do buy it you will never want to sell it. These are a lot of fun to drive.
Old Mar 12, 2009 | 03:53 AM
You can also check the driver's side exhaust manifold to see if it goes under the engine or back. If it goes under the engine then you won't be able to run true dual exhaust. This manifold allowed the 65-70 B/C bodies to run dual exhaust:
http://www.themotorcompany.com/Full-...d-p-16158.html
Old Mar 13, 2009 | 09:02 PM
'70CutlassHoliday's Avatar
Be sure to check the frame for rot, I look at a friends '69 convertible and the car overall looked decent but I touched the frame and thought it was going to crumble
Old Mar 14, 2009 | 07:39 AM
Oldsguy's Avatar
Past Administrator
that 12 bolt is only a cover. That rear is actually a type "O" rear and has 10 bolts on holding the carrier. You can search this site as there are numerous posts about that subject. Just so you know...
Old Mar 14, 2009 | 08:13 AM
MN71W30's Avatar
Uh oh, you just had to mention that rear end.
gearheads78
May 12, 2024 09:36 AM
spiderjason
Oct 7, 2010 08:00 PM
oldsowner1977
Mar 31, 2009 09:26 AM
IB ATEST
Jan 27, 2009 12:32 PM
WasteOfMind00
Apr 18, 2007 08:10 AM
