w33 70 Delta new question
Old Jan 24, 2010 | 07:22 AM
kjr442's Avatar
Kjr442
Can any one tell me what the H.D. wheels consisted of? I think they are wider, but that may be the tire size that is on it. I like the wide stance. Look at my pic's to see what I am talking about. Thanks
Old Jan 24, 2010 | 08:56 AM
wmachine's Avatar
Trying to remember member
For '69 and '70, the HD wheels (403898) are also 15" x 6". Included in your J55 heavy duty power disc brake package.
I presume that starting in '69 they went to a lighter standard 15" x 6" wheel, because these "heavy duty" wheels were the standard 15" x 6" wheel in '67 and '68.
I also believe these heavy duty 403898 wheels should be stamped 15" x 6" JK inside, but I have not verified this.
Old Jan 24, 2010 | 09:01 AM
kjr442's Avatar
Kjr442
Thanks Kurt, They just look so wide. Do you know what made them H.D. ,was it thicker steel, or more time on welding?
Old Jan 24, 2010 | 09:35 AM
wmachine's Avatar
Probably both. A few years earlier the HD 15" wheels were actually reinforced with a plate, but not these.
Old Jan 24, 2010 | 02:19 PM
kjr442's Avatar
Kjr442
Kurt Your a wealth of knowledge, thank you.
Old Jan 24, 2010 | 03:52 PM
copper128's Avatar
Lt. Buzzkill (ret.)
The 15" heavy duty wheels used in '67 & 68 had a solid, unvented center disc and were made by Kelsey-Hayes. They're quite heavy and if I recall correctly, the centers are riveted into the rims. Was this the same wheel used in '69-70?
Old Jan 24, 2010 | 03:57 PM
wmachine's Avatar
I just have a lot of resources and I read them a lot!
Old Jan 24, 2010 | 04:00 PM
kjr442's Avatar
Kjr442
Wow,Interesting. I need to pop off a hub cap and see. thank you ,it is so cool learning all the different things about these cars.
Old Jan 24, 2010 | 04:03 PM
kjr442's Avatar
Kjr442
Hey Kurt, did you find anything that you were not expecting in my info, I sent?
Old Jan 24, 2010 | 04:18 PM
wmachine's Avatar
They should be the same as the *heavy duty* wheels from '69 and '70. You say heavy duty, but there is only one 15" wheel option in '67 and '67. But it *is* the same wheel that carries the heavy duty designation in '67 and '70.
Apparently all 88 and 98 15" wheels are the same in '67 and '68. Bear in mind that the standard wheel was 14" in '67-'68 and 15" in '69-'70.
Old Jan 24, 2010 | 04:49 PM
wmachine's Avatar
Nothing bad or out of place, for sure! That car has every piece of high performance that Olds could add in 1970: W33, M41, J55, and B07.
Old Jan 24, 2010 | 04:56 PM
kjr442's Avatar
Kjr442
Thank you Kurt, ya gotta love it.
Old Jan 24, 2010 | 05:41 PM
toro68's Avatar
Hi Kurt,
Do you plan to be at the 2010 Nationals in Mass?
The reason why I ask, I have (4) 15x6 rims and one 15x7 JJ code unit.
All are Oldsmobile steel wheels (not teh SSI or II jobs). If you are going to be there , I would like to see these rims first hand .
I might set up as a vendor for the show.
Old Jan 24, 2010 | 05:50 PM
kjr442's Avatar
Kjr442
I have not made plans for the nationals, I will take some picks and get back to ya. I love what you have done to your toro, I know where one is sitting here in the dallas area. I will stop and ask about it if I ever see someone out.
Old Jan 24, 2010 | 06:03 PM
kjr442's Avatar
Kjr442
Originally Posted by toro68
Hi Kurt,
What did the 15x7 jj wheels come off of? or do you know.
Old Jan 25, 2010 | 07:04 PM
wmachine's Avatar
Hi Kurt,
Yes, I certainly plan to be there!
I don't show 15 x 7 rims showing up until 1973.
Old Jan 25, 2010 | 07:12 PM
copper128's Avatar
Lt. Buzzkill (ret.)
I was just out in the garage checking on some parts for people and took a look at my '67-68 15" wheels. Turns out they are not marked with the Kelsey-Hayes "K-H" stamp. The only stamps I could find on them were 15 and LC on the outer rim near the valve stem. Since they have tires on them, I couldn't check for stampings on the inside.
The standard 14" wheels from my '67 Delmont are stamped K-H in the lug area. The 15's were original to my '68 Delmont convertible.
Old Jan 26, 2010 | 07:26 AM
66400's Avatar
On the inside of one of my wheels I found:
JK H 15X6 850 2E USA 29 M7
Not in this order but stamped randomly.
Henry
trowto
Jun 4, 2014 06:30 PM
ah64pilot
Sep 19, 2012 10:55 AM
trowto
Jun 12, 2011 08:23 PM
kjr442
Jan 5, 2011 07:11 AM
DAN76
Jun 14, 2010 02:01 PM
