rebuilding the W33 455
I have started, but have limited time to work on it so it is moving slow. I pulled the engine and disassembled the it completely. I found two bad rod barrings, two bad rods, and two bad pistons. This thing was ready to blow. I am lucky, the block was all good it did not need to be bored and I had a good virgin crank for it. I was able to find stock rods and pistons. everything is balanced and ready to go. The cam and lifters were good too. I am too lucky. I am replacing the balancer and oil pump. new rings, barrings, heads are good , but I am replacing the valve springs, guides, and seats, and a lite surface. this I think will bring her back to life. Any positive input will be welcomed. Thank you. I am not sure how to insert my pics but I have a new album that I started for this.
You should consider replacing the camshaft and lifters as well since you are changing the top end of the valve train already. It wouldn't cost you much more considering the whole balance of things.
cam
I was thinking the same way but the machine shop has checked it all out and said it is fine. you think I should anyway?
) but it shouldn't be that much when compared to what you are going to be spending already.http://www.summitracing.com/search/P...p/?Ns=Rank|Asc
After a closer evaluation I have made the decision to replace the cam, lifters and valve springs. I had to replace one valve too. I was ok with the cam, but after a good cleaning I found some pitting, so Oldsguy you were wright !! Thank you for the input.
I am in need of the right cam for this car. can anyone help with specs for the camshaft for the w-33 , maybe same as the w-30 ? I can't find any specs on it. I have the 2:93 rear end on this and don't want it fall on it's face.
Old cam/ new cam
I do agree, and did want to keep it but it is just to pitted up. If I need to I will have one made.A special ground camshaft can be had, and not all that bad on the price considering.
Same as the 442 and W30 auto cam, W32, and W34.
I have now paid a total of 2,102.90 for parts and machine work. I had estimated around 1500.00 to 2000.00 Not to bad I guess. I am just lucky to have it all like the factory did, the block still retains the factory bore. I replaced the cam and bearings as stock/442 spec, lifters, one valve, all new valve springs,seats,guides,valve job, two new stock G M. pistons and rods, I replaced the crankshaft with a used virgin-GM. replacement and is now 10 over. new rings , bearings, balance engine, line hone, freeze plugs,oil pump,new balancer,and timing set. One more thing ,correct 455 blue. If I can this weekend I will complete the build and add new pics of completed engine. next weekend I could maybe re-install this thing and break in the cam. I can't wait to drive this thing with a fresh engine, she should really move.
I bleive the same spec on a W-33 should be the same as a W-34.
I love that woman , even before she sang 455 rocket. I am looking at this cam and on the end of it I can see a 867 that is white looking not a stamp,and down the sides in between each lobe I can see a 38 9410 on one side the other 5 c f d
front bumper
