Removed pcv..replaced with breather..what do I do with vacuum hose.
Old May 17, 2016 | 02:35 PM
navvet's Avatar
Deleted pcv...so what do i do with this vacuum hose...it leads to base of carb.
Old May 17, 2016 | 03:08 PM
Put a vacuum cap on the carb port.
I don't know if you realize, with no PCV system the exhaust blowby gases are likely to end up in the passenger compartment. I very briefly had my PCV removed and it got smelly in a hurry.
edit: Um, that isn't the PCV hose I was thinking of. There should be a 3/8" hose coming off the PCV valve to the base of the carb. That looks like a vacuum line for the thermal valve on the air cleaner.
Old May 17, 2016 | 03:19 PM
As Kenneth stated just cap the port at the carb. I'll add that the other issue you may run into is if you have blowby, the engine will push engine oil out the fill tube or dipstick. I would also look for a 14" air filter that fits the air cleaner housing.
Old May 17, 2016 | 03:25 PM
navvet's Avatar
OK on the filter size...I'll make that change when this one gets dirty. I did put a breather cap in place of the PCV....And you are all correct....didn't take long for fumes to get in car,
Would a filtered valve cover breather work..(They look like mini air cleaner)
Old May 17, 2016 | 03:30 PM
No, it will just slow the smoke down a bit until it gets contaminated.
navvet's Avatar
Here is a better look of the pcv breather
Old May 17, 2016 | 05:33 PM
I think the best option is to connect the PCV valve.
Old May 17, 2016 | 06:32 PM
4speed455's Avatar
X2 and while your at it replace that fuel filter. Don't replace it with the see through glass filter though. They have a tendency to crack and leak.
Old May 17, 2016 | 06:47 PM
steverw's Avatar
Your new air cleaner may have a punch out hole in the bottom pan. Should have come with a plastic adapter for that purpose to connect to the PCV hose. My PCV connects to a large 3/8 port at the bottom of the carb. I would use the PCV if possible.
Well the first post just disappeared, so i made this one, then the first one came back. I tried to delete it but now it wont go away... lol, oh well.
Old May 17, 2016 | 07:08 PM
Actually the punch out in air cleaner base is connected to a breather that would be on the opposite side of the engine from the PCV to aid if the PCV cannot take care of the blowby. It is no way used for a PCV.
Old May 17, 2016 | 08:20 PM
4speed455's Avatar
I run a pcv valve in the driver side valve cover connected to the big port on the carb, and a breather on the passenger side valve cover. My current MT valve covers only had one side drilled. They are the old style with the rocket logo. I didn't want to drill the other one, so I put the breather on the oil filler neck.
Old May 17, 2016 | 08:37 PM
Why on earth would you remove your PCV valve?
Old May 18, 2016 | 04:54 AM
m371961's Avatar
X2. If you are getting oil or smoke back in the engine through the PVC system you have other problems.
Old May 18, 2016 | 06:51 AM
There is absolutely NO reason to remove the PCV valve. The PCV doesn't hurt performance in any way and it helps with fumes. Deleting it frankly shows a lack of understanding in how engines work. If you did this for looks, stop it. Also, there are LOTS of ways to run a PCV valve that don't require it to plug into the valve covers. See the 1970 W-30 intake, as an example.
Old May 18, 2016 | 10:38 AM
navvet's Avatar
Few items...very limited smoke if any coming from valve cover. When I run it hard and for long distance I get some.
My goal was to and is replacing the original air cleaner holder as you see in photos.
The base of the air cleaner holder does have a cut out for a 1/2 line. I will be installing a rigid hose and installing a PCV back into the valve cover where the original one was located.
In previous posts I had inquired about changing the air cleaner assembly and had asked for suggestions on PCV and what to install in place of old PCV and I was sent photos of what I now have (The chrome breather).
And if you going to give out advise Joe I would appreciate if you eliminate your degrading comments about my knowledge of engines....that attitude doesn't fly
Old May 18, 2016 | 10:52 AM
navvet's Avatar
Also i have two fuel filters...one at pump and the one noted at base of carb....i have insulated it due to its location. That area as you know gets hot. I have had that set up for three years and has eliminated contamination issues. I'm comfortable with it.
Old May 18, 2016 | 12:52 PM
If you are referring to this prior thread, we provided info on how to configure the fresh air breather, not the PCV valve. I think the confusion comes from the unusual configuration of the early 1960s Oldsmobile PCV valve, which does not work like a modern one. I assume your original valve looked like this:
Unfortunately, these really don't work that well, which is why they were replaced after 1964 with the more conventional PCV system. If you want to retain this original valve, use the fitting that bolts to the underside of the aftermarket air cleaner, as shown in the older thread.
If all you care about is functionality, I suggest something like what I did on my 1962. Get one of the breather caps that has a hole for a PCV valve:
Install this in one of the valve covers and connect the PCV valve barb to manifold vacuum below the carb (or the large port on the base of the carb - you can tee it into the brake booster line). Use either an open breather on the other valve cover (or oil fill tube) or use a closed breather with a hose to the port in the air cleaner. The latter is a little better for collecting and controlling any fumes.
Old May 18, 2016 | 01:57 PM
76olds's Avatar
Hookers under Hood
Wow,
Your engine bay is nice and clean for the age of your car.
I wish mine looked half as good in my 76.
Very nice!!
Eric
Old May 18, 2016 | 02:05 PM
navvet's Avatar
Every time it is on a lift...I get some quality time giving the engine a cleaning. Old man use to tell me "you can't spit a leak on a dirty engine "
63super88
Jan 23, 2014 08:17 AM
tgilligan
Mar 22, 2013 01:35 PM
Pacecar
Dec 22, 2012 08:24 AM
jstrits
Nov 26, 2011 05:58 AM
mmurphy77
Hurst/Olds
Apr 12, 2011 10:03 AM
