rear floor pan for 73 olds delta 88
I have rust of the rear floor pan, where your feet would go in the rear seat (both sides). Any ideas where I can get a replacement? If not, any ideas of how I could replace this myself? Thanks.
The only way you will be able to find a replacement is to locate a donor car with good floor pans. Aftermarket panels and sheet metal aren't made for the B body. You might start at the following place. I have never used them before, but they might have what you are looking for.
http://www.desertdogautoparts.com/index.html
Like olds64 said, you can find a donor car from 71-76 of your body type. Im pretty sure there are aftermarket floorpans for Impalas/Caprices 71-76. Dont know if chevy floorpans look similar to BOP's but they should fit.
Ed
Ed
That might be worth looking into. I doubt a fender or a quarter panel would fit from a Caprice/Impala, but a floorpan, package tray, or kick panel might be close enough that it wouldn't matter if it was a bit different.
jstrits
February 7th, 2016 11:33 AM
Oldracerjones
March 3rd, 2014 07:38 PM
