rear floor pan for 73 olds delta 88
Old Feb 7, 2008 | 10:07 AM
rutsski's Avatar
I have rust of the rear floor pan, where your feet would go in the rear seat (both sides). Any ideas where I can get a replacement? If not, any ideas of how I could replace this myself? Thanks.
Old Feb 7, 2008 | 10:16 AM
The only way you will be able to find a replacement is to locate a donor car with good floor pans. Aftermarket panels and sheet metal aren't made for the B body. You might start at the following place. I have never used them before, but they might have what you are looking for.
http://www.desertdogautoparts.com/index.html
Old Feb 7, 2008 | 01:36 PM
rutsski's Avatar
thanks for the tip
I checked out the website and sent in a request. Thanks for the tip!
Old Feb 12, 2008 | 01:43 PM
Edveen's Avatar
Like olds64 said, you can find a donor car from 71-76 of your body type. Im pretty sure there are aftermarket floorpans for Impalas/Caprices 71-76. Dont know if chevy floorpans look similar to BOP's but they should fit.
Ed
Old Feb 12, 2008 | 03:23 PM
That might be worth looking into. I doubt a fender or a quarter panel would fit from a Caprice/Impala, but a floorpan, package tray, or kick panel might be close enough that it wouldn't matter if it was a bit different.
jstrits
Feb 7, 2016 11:33 AM
AzChevs
Oct 8, 2014 10:13 AM
ruby1520
Jun 19, 2014 02:28 PM
Oldracerjones
Mar 3, 2014 07:38 PM
rcktdoc
Jan 6, 2014 06:10 PM
