Pertronix Ignition Installation Question
Old Oct 11, 2011 | 08:54 PM
Mak's Avatar
Mak
I've decided to install a Pertronix electronic ignition conversion. Hopefully some of you that have it done can answer a few questions for me. The parts house I'm buying from has standard or lobe-sensing. I'm not sure what lobe-sensing is... or which one I need? Can I use my stock coil... or do I have to replace with their Flame-Thrower coil? (I'm considering the coil even if it's not mandatory.) The online instruction make it sound pretty simple, but they seem a little vague... can anyone give me a step-by-step for dummies?
Old Oct 11, 2011 | 09:11 PM
The lobe sensor should allow you to use your own distributor without further modification, as it senses the peaks of the distributor cam lobes without the need for additional magnets.
The system should work fine with your original coil. Frankly, under normal operating conditions, their extra special coil will probably provide no noticeable benefit.
See their instructions, which answer most questions, here.
Old Oct 11, 2011 | 09:35 PM
Mak's Avatar
Mak
Okay, so sounds like I want the lobe-sensing one... and I'll start out using my existing coil and a new cap & rotor.
I read in an older thread about having to replace the 12V wire to coil with a constant key-on power source... but I don't see any mention of that in the Pertronix instructions?
Old Oct 11, 2011 | 10:01 PM
Mak's Avatar
Mak
I sorry, what I meant to say was when the guy at the parts house was looking up the part he asked me if my 425 was with or without a lobe-sensor???
Old Oct 12, 2011 | 03:46 AM
There were CD ignition units that early in a few cars, but if you don't have a separate OEM electronic box and a special CD distributor, as pictured, then yours is just a regular points and condenser.
Old Nov 19, 2011 | 07:55 AM
KQQLCAT's Avatar
I know I am late to this thread but I would recommend the Pertronix III. I used it and it was very simple to install. Use the coil they rcommend.
Pat
real57vetteguy
Mar 26, 2020 08:42 PM
TomType1
Apr 1, 2014 07:48 PM
yeahbuddy
Sep 13, 2011 01:19 PM
amphicar770
Oct 31, 2010 05:38 PM
Chuck C
Apr 29, 2004 02:12 PM
