No SPARK after changing rotor, ignition coil cap & button
Old Mar 14, 2019 | 08:55 AM
Stephen0523's Avatar
Hello all my 307 Oldsmobile Delta 88 1984 cranks very well but all of a sudden had no spark. I just replaced the cap, rotor, ignition coil and button but still no spark any ideas what I should look at next?
Old Mar 14, 2019 | 10:06 AM
Oldsmaniac's Avatar
With key on make sure you have 12v at the coil lead on distributer cap. Look for cracked wire on pick up coil in distributer.
droptopron's Avatar
delete
Put the old parts back on & see if it starts. New parts can be defective
Old Mar 14, 2019 | 10:16 AM
I Oldsmaniac I Old maniac is there a video or any kind of visual direction to help me with the instructions you just gave me?
Old Mar 14, 2019 | 11:58 AM
Oldsmaniac's Avatar
Check Youtube for GM HEI
Old Mar 14, 2019 | 06:27 PM
If you look at the top of the cap where the wires plug into underneath, there are 2 markings. 1 is for batt (coil+) the other is tach (coil-). See if you have power at the Battery+ terminal wire with the key on.
Old Mar 15, 2019 | 06:18 AM
droptopron's Avatar
delete
Any chance you left out the coil contact that goes between the coil & the cap? (kinda bent up wire lower right corner of the pic)
Old Mar 15, 2019 | 02:23 PM
I have everything installed except Circled in red attached.
Old Mar 15, 2019 | 03:38 PM
There's your problem. That's the ground connection.
Old Mar 15, 2019 | 03:51 PM
LOL I thought the ground was the little black wire that was screwed down to the coil. I just checked for 12 V when the key is in the on position and I do have 12 V I will have a look at the coil instructions to see how that piece I left out sits in there.
Old Mar 15, 2019 | 04:03 PM
Well I put that extra grounding wire on and cracked her over but all I smell is gas I’m pretty sure they’re still no spark I didn’t have time to check the plug for spark
Old Mar 15, 2019 | 07:56 PM
cherokeepeople's Avatar
lets clarify this.the way it sounds it was working fine,til one day you went to start it and no spark,so you decided to start with the cap,rotor and coil??my guess would be the module took a dump.or as mentioned a wire on the pickup coil.
Old Mar 15, 2019 | 08:31 PM
So how does that black wire get connected to the vehicle ground (battery negative)?
Old Mar 15, 2019 | 09:10 PM
Did you try advancing the distributor a bit while someone cranks the engine?
Old Mar 16, 2019 | 07:25 AM
Hi olds cutlass, I have not tried advancing the distributor. That would not resolve why there is no spark? I think I may replace the module & the little diode
Old Mar 16, 2019 | 07:28 AM
Sorry I thought you fixed the no spark issue but it still would not fire.
Old Mar 16, 2019 | 07:30 AM
Sorry, still no spark. I have 12V on the coil, but the module and diode looks rough, never been replaced, so that will be the next step.
Old Mar 16, 2019 | 02:42 PM
make sure you put the grease under the module before you put it in.
Old Mar 16, 2019 | 03:50 PM
Grease under the Module, hmmm, it was dry as a bone. The 2 part shown (The Ignition Module and the diode will be replaced next)
Old Mar 16, 2019 | 07:05 PM
there should be a little grease pack with the new module,its for heat transfer,
Old Mar 16, 2019 | 09:14 PM
You don't need a lot of the heat sink compound on the back of the module. The silver can is not a diode its a capacitor.
Old Mar 17, 2019 | 06:35 AM
Different prices on these modules.
Anyone know what would be the best? Is more money better?
https://www.summitracing.com/int/sea...keyword=module
Old Mar 17, 2019 | 04:53 PM
Not necessarily, go with the DUI or the A/C Delco.
Old Mar 17, 2019 | 07:39 PM
Agreed, quality brand vs price. Also note some of those are 7 pin modules for CCC systems.
Old Mar 17, 2019 | 09:21 PM
76olds's Avatar
Hookers under Hood
I like the DUI module myself. However A/C delco, Accel are just as good.
Eric
Old Mar 19, 2019 | 08:16 PM
capacitor & module ordered. Fingers crossed she starts!
Old Mar 30, 2019 | 12:17 PM
The module and capacitor arrived yesterday. On the back of the module should I put dielectric grease or just regular grease?
Old Mar 30, 2019 | 12:58 PM
You really need heat sink compound (zinc oxide paste) for that as it assists greatly with thermal conductivity. Heat is what kills electronics, and using the compound helps the module transfer the heat it generates to the aluminum distributor housing.
Old Mar 30, 2019 | 09:12 PM
so zinc oxide paste is that dielectric grease we use for spark plugs we Use for spark plugs or or nickel grease that silver stuff?
Old Mar 31, 2019 | 07:32 PM
New Module and Capacitor installed, still no start.
Old Oct 4, 2019 | 02:08 AM
  #31
Sorry for the late reply on the subject life got away from me!
It ended up I had cracked I had tooth on the timing gear and the chain was broken!
But I was glad I replaced all the ignition stuff , she fires right up and runs great!
Thank you all for your help!
Old Oct 4, 2019 | 10:36 AM
  #32
Glad you got it taken care of.
Matt Hohmann
Aug 5, 2013 12:39 PM
4-Speed
Jan 14, 2013 06:27 AM
wikkonado
Jun 1, 2010 05:59 PM
ZOlds
Mar 3, 2010 05:37 AM
