No SPARK after changing rotor, ignition coil cap & button
Hello all my 307 Oldsmobile Delta 88 1984 cranks very well but all of a sudden had no spark. I just replaced the cap, rotor, ignition coil and button but still no spark any ideas what I should look at next?
With key on make sure you have 12v at the coil lead on distributer cap. Look for cracked wire on pick up coil in distributer.
If you look at the top of the cap where the wires plug into underneath, there are 2 markings. 1 is for batt (coil+) the other is tach (coil-). See if you have power at the Battery+ terminal wire with the key on.
LOL I thought the ground was the little black wire that was screwed down to the coil. I just checked for 12 V when the key is in the on position and I do have 12 V I will have a look at the coil instructions to see how that piece I left out sits in there.
Well I put that extra grounding wire on and cracked her over but all I smell is gas I’m pretty sure they’re still no spark I didn’t have time to check the plug for spark
lets clarify this.the way it sounds it was working fine,til one day you went to start it and no spark,so you decided to start with the cap,rotor and coil??my guess would be the module took a dump.or as mentioned a wire on the pickup coil.
Hi olds cutlass, I have not tried advancing the distributor. That would not resolve why there is no spark? I think I may replace the module & the little diode
You really need heat sink compound (zinc oxide paste) for that as it assists greatly with thermal conductivity. Heat is what kills electronics, and using the compound helps the module transfer the heat it generates to the aluminum distributor housing.
Sorry for the late reply on the subject life got away from me!
It ended up I had cracked I had tooth on the timing gear and the chain was broken!
But I was glad I replaced all the ignition stuff , she fires right up and runs great!
