Newb w/67 delta 88 ?'s
Old Nov 5, 2007 | 04:40 PM
arnyishere's Avatar
1967 Delta 88?
Hey to all out there in olds land!!!!! I am new to the forum. I have finally recieved my 67' Olds Delta 88 and have some questions....
1. What series of 88 is it?
2. Motor is stock 425 w/ Dual exhaust...what motor series is it.
3. Give me any opinions on light engine mods(i.e. carb, exhaust, ignition.)
right now it has a 2 barrel that was switched from a 4 bbl in 96. I still have the original manifold for it. Any recommendations and comments welcome!!!!!!! Here she is........
Old Nov 5, 2007 | 06:37 PM
Welcome to the website. That is a sweet car.
Old Nov 5, 2007 | 08:36 PM
2blu442's Avatar
Hello Arnie
If you wanted to move it back toward original I should have a carb I got on a 1967 Olds 98 425. It would need rebuilt, but it should be the correct number for your car. If you weren't concerned about being original I would consider a Performer intake and a newer quadrajet that didn't have the divorced choke. You would need to get an electric choke rather than the stock setup to work with the Performer. John
Old Nov 6, 2007 | 04:49 AM
arnyishere's Avatar
1967 Delta 88?
what would i be better off with? Will the original give soome ooomph....or put an Edelbrock on the stock 4bbl manifold? Thanks.....oh yeah....how much for the original 2 blu442? By the way.....bad a$$ 442 man!!!
Old Nov 6, 2007 | 04:53 AM
Oldsguy's Avatar
Past Administrator
Arnie, to answer your questions, the 88 was a model in itself not a series of another model. The 425 may have been the optional big block for the 88 model that year. I am not sure and will have to check.
Old Nov 6, 2007 | 06:48 AM
arnyishere's Avatar
1967 Delta 88?
What I had meant Oldsguy is the car a custom, holiday or what. And how can I tell which series of the 425 series is it ( 365hp or 375hp?)? Thanks again.
Old Nov 6, 2007 | 09:27 AM
Oldsguy's Avatar
Past Administrator
Will have to check my references tonight.
Old Nov 6, 2007 | 04:30 PM
arnyishere's Avatar
1967 Delta 88?
It is a Delta 88 Holiday Coupe per VIN. It did have a 4bbl stock but was changed to a 2bbl in 1996.
Old Nov 7, 2007 | 03:23 AM
arnyishere's Avatar
1967 Delta 88?
I have just found some pics of the car befor its paint job in 95'. It had what looks like pinstripes down the side also. But the main thing is...how can I tell which 425 it is. Are there engine codes or what not? Thanks guys!
Old Nov 8, 2007 | 07:52 PM
frdmftr's Avatar
Freedom Fighter
Very nice looking Delta. I have quite a bit of history and literature for the 67's (Delta's). I have a 67 convert myself. My dad (serious car collector) taught me to collect anything I can find that related to the model/year. I took his advice and now have quite a collection.
Shoot me an email and I will scan some info for ya.
BTW- your car color, if it matches original, is Saffron, same as mine.
Old Nov 9, 2007 | 07:26 AM
arnyishere's Avatar
1967 Delta 88?
Hey there 2blu442. I was wondering what you wanted for the carb and what it would be for shipping. Thanks.
Old Nov 9, 2007 | 08:10 AM
2blu442's Avatar
1967 4 bbl swap
PM sent, but a question for the the rest of the board, does anybody know if the throttle rod from the firewall to the carb is the same on a 2 and 4bbl? I'm already expecting that Arnie will need a divorced choke and air cleaner to go with a factory 4bbl carb, and he has the intake but do you guys forsee anything else he would need to make the swap? John
Old Nov 9, 2007 | 12:13 PM
kevinkpk's Avatar
I am thinking the throttle for both a quadrajet, and a 2gc are center of the carb body? So I "assume" it will work.
tmack88
Jun 20, 2012 09:05 PM
Art Vandelay
Mar 21, 2009 09:04 AM
JThw8
23
Feb 12, 2009 10:15 AM
mr quad 442 HO
Nov 1, 2008 06:38 AM
cutlassinvt
Jun 9, 2008 08:33 AM
