New olds owner
Old Mar 24, 2009 | 06:20 PM
64oldsd88's Avatar
New olds owner
I just bought a 1964 Oldsmobile Dynamic 88 2dr coupe. So far i have seen that it came with a 394 cu motor. How do I go about seeing if it has the original motor? Where would the engine code be at on the block? i'm guessing that the bolt pattern is 5x5?
Old Mar 24, 2009 | 06:53 PM
64oldsd88's Avatar
vin - 844M317635
Old Mar 25, 2009 | 07:36 PM
Danny Wiseley's Avatar
I'm not sure about the number location, but the wheels are 5 on 5. You might also find some LH threads on the LH lug bolts--mine had 3 on the front and two on the back. I suppose the other five had already been broken off and replaced. . .
Old Mar 25, 2009 | 07:39 PM
citcapp's Avatar
Welcome to the site. Sounds like a nice find
Old Mar 26, 2009 | 05:27 AM
Oldsguy's Avatar
Past Administrator
'64s are nice. Welcome to our site.
Old Mar 26, 2009 | 06:07 AM
Welcome
Welcome aboard.
Hang in there some 88 gurus will soon chime in.
Old Mar 26, 2009 | 09:14 AM
rocketraider's Avatar
Oldsdruid
Not really easy to tell if engine is original since they have no VIN derivative on them anywhere. Look on the driver side head, right above the exhaust manifold center ports and you'll see a number stamped into a machined pad. The first letter should be an H or J, then the engine serial number (it will not match the car VIN), then export low compression and Starfire engines have a suffix letter.
About the best you could do would be to see if the engine build date code is close to and ahead of the car's build date.
blunosr68
Apr 23, 2019 06:15 PM
lmetcalf
May 31, 2012 06:23 PM
raincitymarc
Feb 23, 2008 08:50 PM
jrblanke
Jan 27, 2008 10:12 AM
redrumloa
Mar 10, 2007 06:45 PM
