MY 70 Delta 88 pics
Old Jun 1, 2008 | 11:44 AM
70-delta88's Avatar
MY 70 Delta 88 pics
Old Jun 1, 2008 | 11:48 AM
70-delta88's Avatar
more
Old Jun 1, 2008 | 11:53 AM
70-delta88's Avatar
and more
Old Jun 1, 2008 | 11:59 AM
That is a beautiful car! I really like the color and the wheels. I especially like the heater hose you got for your heater core. I nearly matches the color of the car. Where did you get it?
Old Jun 1, 2008 | 02:44 PM
Pfiffle's Avatar
Thats a nice, clean, full sized beast. Those 2 door Deltas. I think I'm starting to like them better than the Cutlasses. I also like the bench seat/column shift. Rims are nice because they're not 22's or 24's or something stupid like that. I like that color also. Nicely done.
Tom.
Old Jun 1, 2008 | 04:20 PM
70-delta88's Avatar
THANKS
I own this car for a long time I pick her up in the about in 84 to replace the 4-door my parents game me that they bought new ,lost the 4-door to major frame rot
this car was white and black vinyl top wich I did not like either combo
so I changed her to sherwood green this was the color of the 4-door and got rid of the vinyl top
Would you believe I painted this car 20 years ago ,the paint not perfect but she still looks good the motor and drive trian was rebulilt in the same time frame ,detailed the engine bay about 10 yrs back and I been tinkering ever since
the rims is also from the mid 80's 15" american racing with 60 series rubber all around
I had to get the motor rebuilt again about 3 yrs ago lost comp in one clyinder
so this time had the motor built right balance/blue printed forged pistons
heads reworked for large vavles mild porting roller rockers and few other goodies this realy woke this motor est hp 330-340 for a 60 over 350 ci
custom bent 2" duel exhaust mated off the stock manifolds with glass packs
with all this room in the engine bay headers will not fit ,even had a set of duel exhast manifolds for a cutlass still no go ,will not clear the stearing box
Okay the heater hose I got from Summit it is goodyear hose
one thing I do like about this car I never see one like it in a show or cruise
Old Jun 1, 2008 | 06:44 PM
Rallye469's Avatar
GREAT car!
I've been turned on by these big ones lately. Great color combo too.
I wished the rubber filled up the wells a bit more though...and I don't mean
16's or 17's. Just some big ol' meats under her.
What about that alt. bracket? Chromed? Powder coated? Rattle canned?
Looks nice!!!
Old Jun 1, 2008 | 09:12 PM
Edveen's Avatar
Very Very nice interior!
Old Jun 2, 2008 | 01:51 PM
70-delta88's Avatar
intake,valve covers ,exhaust manifolds and all brackets,pulleys and done in the hi-temp performace coating(powder coating)
no more dealing with dulling out alum.
only a couple of pieces are chrome, Alt and some minor accessorys
the exhuast manifolds are starting show wear but theses have been coated well over 10 yrs ago
Old Jun 2, 2008 | 01:56 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Originally Posted by Pfiffle
. Those 2 door Deltas. I think I'm starting to like them better than the Cutlasses..
Whenever you're ready to convert, I will welcome you to the dark side
Old Jun 2, 2008 | 02:01 PM
Redog's Avatar
^^ Me too..
Very nice and clean car, I like very much
Old Jun 2, 2008 | 02:16 PM
70-delta88's Avatar
what you dont see in the photo in the dash I inserted a tach when the clock belongs and with out modifing the face of the dash for fit ,only thing is is not
in perfect view. I did not want to hack up the dash
still needs some more dash work to clean up from wear from time,faded wood grain finish ,brush stainless finish trim is yellowed on the edges
I pick at a little at a time
by the time I am finished then its time to start all over again
also It took me along time to find sport mirrors that will work on the doors(that was last year),thats why for now I just painted them trim black
I tried a lot of different mirrors ,I got **** off every time I close the door or hit pot hole the mirrror head would shift "I HATE BALL SOCKET MIRROR HEADS"
Old Jun 2, 2008 | 02:23 PM
Pfiffle's Avatar
I know. I have a Cutlass. But also a 1970 Ninety Eight 4 door. But thanks anyway. I'm already there..
Tom
Old Jun 2, 2008 | 04:08 PM
The coating on your exhaust manifolds looks good. How did you run dual exhaust without the dual exhaust manifold for the driver's side? Did your exhaust shop fit the pipe in there around the pitman arm, or did you have to get one of the Thorton reproductions?
Old Jun 2, 2008 | 08:13 PM
Rallye469's Avatar
Where did you have it done?
RI's not too far from NY...
Old Jun 3, 2008 | 02:48 PM
70-delta88's Avatar
on the exhaust
Jims Custom Exhaust in South County R.I.
stock manifold ,right side ,made a bock off cap were the cross over pipe would go too and used the rear exit for the exhaust pipe
now custom bend to left side manifold he went down and around the drag link with a slight loop back up to level back out ,the drag link is above the pipe and it is set for just enough clearance so it wont rub on the pipe he also slighty egg shaped the pipe that passes around the bottom of the drag link for slightly more ground clearance wich turn out not to be a problem and the pipes are not in away of anything
he used 2" aluminized pipe with H-pipe configure tuck up neat into glass packs
and the tail pipes exit under the bumper on a slight angle with stainless tips
from the backside of the car you cannot see any pipes till the curl down under
the bumper, the whole system is welded
first tried a set of flow masters mufflers ,did not like them they resonated sound into the car he exchange them and install glass packs and now perfect
the sound goes out the back of the car instead through the floor
I hope I explained it alright
Old Aug 15, 2008 | 08:42 PM
dwsshay's Avatar
70 hulk
70 delta 88
nice car i have a 70 also sherwood green convertible put 20's on itmakes it look greatreal head turner, slowy finding parts for it but fun looking, rides great better than most new cars,again very nice, nice engine hope i can get mine some what close to that also, cruse on
cutlassgal
Sep 20, 2011 04:46 PM
1969w3155
Jun 14, 2011 10:12 PM
DenVIP
46
Jan 9, 2010 09:51 PM
russell7088
15
Oct 19, 2009 02:01 PM
69deltaconvert
Aug 19, 2006 09:13 PM
