1966 Delta 88 gas tank INFO NEEDED
Old Aug 15, 2008 | 08:31 PM
Canadian Delta's Avatar
Can anyone tell me if any other 1966 models might have the same tank as my Delta 88??
Thanks so much
Old Aug 16, 2008 | 05:49 AM
Thanks so much
Unfortunately, Hollanders shows it as 1966 Olds full size except 98 only. Sorry.
Old Aug 16, 2008 | 11:45 AM
rocketraider's Avatar
Oldsdruid
A 1965 Olds B-body tank will bolt in, but you'll need the 1965 sender unit as well. Internal baffling is different between 65-66 and the sender float arm installed in the wrong tank will get hung up on the baffling.
Yup- you'da thunk all GM B-cars would use similar tanks.
Old Aug 17, 2008 | 02:44 PM
I had a hunch. Hollanders is pretty conservative about interchanges like this. On the other hand, good luck finding a usable 65 tank...
Old Aug 17, 2008 | 04:33 PM
Oldsdruid
You didn't ask how I know this...
Had I read the fine print in the parts book and dug far enough into the TIL's I'd have saved meself some grief. As it was, I figured we had a working 66 sender from the old tank so why chance the junkyard 65 sender?
You can guess what happened next. Bah, phooey. And I saw that the float arms were bent different.
The good folks at AutoInstruments up in Martinsville rescued us once again by rebuilding the 65 sender. I recommend their work. www.autoinstruments.com
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
Canadian Delta
Aug 13, 2008 12:08 AM
JoshF85
Oct 20, 2005 12:40 PM
