minimize my sway
Old Aug 30, 2013 | 08:12 AM
HIGHCOMP425's Avatar
minimize my sway
Is there a heavier front sway bar for a 1965 Dynamic 88 vert? (A lot of weight out front with that BB running on radials.) If so, who has one?
Old Sep 2, 2013 | 02:26 PM
Mark in MN's Avatar
I have a 1968 98 convertible and switched the wheels from 14" to 15 x 7 from a late 80's police car. Tires are now 225/70-15 and the car drives much nicer. Tire sidewall rubs a bit on the frame when turning very sharp but everything else is fine.
Old Sep 2, 2013 | 03:53 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Try maximizing your current bar by replacing both the bar-to-frame bracket bushings and the end link bushings with polyurethane. That will stiffen up the stock sway bar quite a bit. Are you still running the original springs? Worn/soft factory springs help the ride but hurt handling. Consider replacing front springs with ones of similar dimensions but higher spring rate. Also, if you haven't already added good gas-charged shocks, do that too.
The addition of a rear sway bar will help a lot with cornering. They're not easy to find, but they are out there. Read this thread for more info:https://classicoldsmobile.com/forums...-sway-bar.html
Old Sep 2, 2013 | 05:33 PM
jaunty75's Avatar
Originally Posted by HIGHCOMP425
minimize my sway
Drink less.
Old Sep 10, 2013 | 12:45 PM
delta7388's Avatar
sway help
Hello,
I've got an 1 1/8" bar up front and a 1" bar on the rear both from P-S-T on my '73 88, they list the same rear bar for your '65.... their mounting system is lame as it all tweaked in the first hundred miles. I've included a few pics of what fixed it --- Now I feel like i'm driving a 4300lb Honda car -- what a difference -- also have 1" trim coil springs alround from Coil Spring Specialties, KYB Gas adjust up front and Monroe Sensatrack load handling shocks on the rear... new control arm bushings alround, ball joints etc.. complete the rebuilt suspension.... oh what a feeling!
EK
'73 88
'67 88
Old Sep 10, 2013 | 12:57 PM
ent72olds's Avatar
Registered Luser
I've seen this set up on some Chevy forums... Not easy to find an original GM set up....
Old Sep 10, 2013 | 01:18 PM
delta7388's Avatar
I should have known that a couple grade 8 bolts and spacers would not keep the bar in place on a B-body olds.... pull it back apart, box the lower arms and incorparate the mounting plates by welding them in, left the bolts in welded and ground down... all good now.... improvise, adapt and overcome....
EK
'73 88
'67 88
65Delta88
Aug 5, 2008 10:19 AM
cola
Mar 15, 2008 03:08 PM
J-(Chicago)
Nov 24, 2007 09:05 AM
miti12
Alero
Jul 27, 2007 09:56 PM
Carleta
Jul 4, 2006 11:44 AM
