Looking for Exhaust for '67 Delta!
Old May 3, 2013 | 06:39 PM
ent72olds's Avatar
Registered Luser
Exclamation Looking for Exhaust for '67 Delta!
Car has dual exhaust. Needs over-axle pipes, resonators and tailpipes. Anyone have ideas where I can find these pre-bent and ready to install? I'm looking to avoid custom bent stuff.....thanks!
Old May 3, 2013 | 06:55 PM
Oldsmaniac's Avatar
I got mine for my 66 starfire from classic exhaust. I assume you are using factory manifolds...
Old May 3, 2013 | 07:37 PM
You'll never find that stuff for a fullsize.
Never.
And if you do, tell me where, and then pull a feather out of a pillow and knock me over with it.
Old May 4, 2013 | 04:47 AM
Oldsmaniac's Avatar
Never.
True thats why he needs to go repro.... although years ago on ebay I found some nos resonators with correct tailpipe stub attached for my 66 Delta duals. The resonators were box design and not round like the repops.
Old May 4, 2013 | 05:36 AM
Yeah, finding these would be one of those needle-in-a-haystack, just-won-the-lottery events where you happen to find the one warehouse that forgot to inventory the stuff in the back corner, and so didn't throw them out 30 years ago.
Which is to say, Don't count on it.
Revolting as it may be to you, go find a good exhaust place and have the pipes bent up right. How often do you crawl under the car anyway?
Old May 4, 2013 | 06:00 AM
Oldsmaniac's Avatar
Since I am a do-it-yourself guy I went repro mailorder. I did the same for the 442. The shops around here will make the pipes if you have a sample otherwise if they bend em they install em...
Old May 6, 2013 | 08:35 AM
ent72olds's Avatar
Registered Luser
You guys are great! Thanks for the responses. I'm not concerned with originality. Maniac, were you happy with the stuff from Classic? Scott says he can sell me exactly what I need. I'm getting ready to pull the trigger.....this car had duals when I bought it. The guy I bought it from says they are factory, but I can't confirm that!
Old May 6, 2013 | 08:52 AM
If there's a place that makes full size exhausts, then jump at it - I had no idea anyone repro'd this stuff.
Old May 6, 2013 | 10:40 AM
Oldsmaniac's Avatar
A factory dual exhaust 67 88 would have come only with the Starfire optioned 425. The left manifold is special so adapting duals to anything but this manifold would be difficult and unsightly. Recently this manifold has been reproduced. Only the Starfire engined optioned full size Oldsmobiles had factory duals in 67. Note if you dont use resonators the exhaust will be somewhat noisy and throaty with stock mufflers. Yes I am happy with classic exhaust but my last order they ended up cutting the long header pipes to save on shipping I would guess.... I would have preferred they left them intact.
Old May 6, 2013 | 11:11 AM
ent72olds's Avatar
Registered Luser
Thanks! I just ordered it. I will check on the manifold and update here......I am curious......
Old May 6, 2013 | 11:19 AM
Thanks for this info, Joe.
I've been checking into local places that can bend a system up, but that's always a crapshoot, and I'd much rather do the work myself, since I don't trust anyone.
A national place that has all the specs for the right bends just seems better than a guy ive bever met, in a run down garage with a tubing bender over an hour away from me, even if that guy does have a good rep on the interwebs.
Old May 6, 2013 | 06:38 PM
ent72olds's Avatar
Registered Luser
I originally was going to have it bent by the guy who did three other cars for me. We looked at it on the lift, and he said the over axle pipes were pretty tough bends, and it wouldn't be cheap. He suggested it would be cheaper to see if I could find them and if I needed, he would install them....
Old May 23, 2013 | 03:59 PM
ent72olds's Avatar
Registered Luser
Joe and Eric, the exhaust from classic was a perfect bolt in......very nice quality. The right side manifold had a cap where the crossover would be. If the car was dual from the factory, would it be that way or was there a specific manifold for dual exhaust?
Old May 23, 2013 | 04:02 PM
Oldsmaniac's Avatar
There was only a specific manifold on the left side. For duals the rt side had a cap on it. Can you get a picture of the left side manifold? It should have an S on it and big swoop to go up and over steering box. This is a factory S manifold that is now being reproduced.
Old May 23, 2013 | 05:44 PM
Funny - after this discussion, I went through my receipts and found that I bought an exhaust system for my Chevelle from Classic Exhaust in 2003.
It fit great and has lasted well.
Old May 23, 2013 | 06:20 PM
Oldsmaniac's Avatar
The S manifold
Old May 23, 2013 | 06:56 PM
ent72olds's Avatar
Registered Luser
Yeah Joe, I will get a pic!
Old May 23, 2013 | 06:58 PM
TripDeuces's Avatar
http://www.kanter.com///productdetai...Cat=34&Prc=170
Kanter has the whole thing
http://waldronexhaust.com/cart/index...Path=61_49_350
Also Waldrons
Old May 23, 2013 | 07:15 PM
Oldsmaniac's Avatar
Originally Posted by TripDeuces
I am not fond of Kanter prices and am not sure if they are just the "middle man". Classic makes their own stuff.
The guy at Waldrons is an idiot. Bought some stuff off of him that was not right and then he argued with me about it thinking everyone has a oxy/acet setup with rosebud tips to heat and rebend his mistakes. He also tried to say the 66 Delta factory duals did not exit where the bracing cutouts were... But if there was something custom i wanted he could do it. As he said this i was holding nos resonators with tailpipes attached in my hand and were not close to what he said was factory that he made... and sent me.
Old Jun 19, 2013 | 02:12 PM
ent72olds's Avatar
Registered Luser
Been a while, but I did finally get a pic of the left side manifold....pics aren't the greatest....
Old Jun 19, 2013 | 02:37 PM
Oldsmaniac's Avatar
Yes that is the correct S manifold for duals. Its nice you have it!
Old Jun 19, 2013 | 07:19 PM
For whatever it's worth, to follow up on what I mentioned earlier, the Classic Exhaust system for the Delta fit great, no sledgehammer or torch work needed.
I think the turndown at the end is a bit long, but other than that they're great.
The only real "downside" is that I said I wanted quiet mufflers, and asked whether he thought I'd need resonators, and he said they'd be quiet and I wouldn't, and these things are fairly loud.
I did install resonators, and that toned it down and gave it a really nice discrete rumble, but the mufflers are still louder than I had intended. Of course, I can buy others later if I want to, but I may get used to the current sound, because it's really not bad, just not OEM quiet.
Old Jun 19, 2013 | 08:28 PM
ent72olds's Avatar
Registered Luser
Eric, you seem to be missing your car there...or did the exhaust outlast the car? I emailed the guy direct, and told him I wanted resonators. His kit doesn't have them. He added them for me. Turned out great....I will try to get a finished pic from the back. I was worried I wouldn't like the tail pipe down turns....but they grew on me!
Old Jun 19, 2013 | 08:37 PM
Yeah, the resonators were no big deal - you can get them for $50-$60 each within a couple of days from a number of suppliers, and they just fit right onto the pipes right behind the axle - All I had to do was trim off the excess tailpipe and push it all together.
I figured I'd go with Scott's advice initially since the resonators were so easy to add later, and since it is very seldom that someone selling something tries to convince you not to buy it.
Old Jun 20, 2013 | 06:44 AM
Oldsmaniac's Avatar
Yeah I would say the turndowns are not quite as factory. Original exhaust had the tailpipe ends cut at a 45 and the there was not much of a turndown and actually not much of the pipe exits could be seen from the rear of the car.
Old Jun 20, 2013 | 06:58 AM
Exactly.
If i had an original example, I'd cut mine to shape, but I'm not messing with them otherwise, at least not this month.
Old Jun 20, 2013 | 05:46 PM
Oldsmaniac's Avatar
Here is a picture that is close to what the factory tailpipe termination would look like for a 65-67 b body
Old Jun 20, 2013 | 05:48 PM
Thanks! Looks about right to me.
I'll keep these for when I'm in the mood to use the SawzAll.
Old Jun 23, 2013 | 10:21 PM
68Delta88's Avatar
This might sound like a dumb question, but why does the "S" manifold have such a weird shape to it? I know a regular manifold has the exit right in the way of the steering box, and needs to be moved rearward, but I don't understand why it has such a huge arch to it. From the picture above, it doesn't appear to interfere with anything. So why is it like that? Clutch pivot?
Old Jun 24, 2013 | 04:21 PM
Oldsmaniac's Avatar
If you look at the picture in post number 20 you see the rag joint on steering column and the actual steering box is right where a normal manifold and exhaust downpipe would be. This is the design on the S manifold needed for dual exhaust that GM came up with and it works.
Old Jun 26, 2013 | 08:02 PM
  #31
Summerof84's Avatar
Got all excited about exhaust for my car. Emailed Classic and zero response. Guess they don't need my business and I was considering 2 or 3 dual exhaust systems from them.
Old Jun 26, 2013 | 08:50 PM
  #32
I'd call him.
He sounded like he was in the process of bending pipes when I talked to him.
He may not have a lot of time for sitting around staring at his computer.
Old Jun 27, 2013 | 05:24 AM
  #33
Oldsmaniac's Avatar
Not defending Classic Exhaust but I have found a lot of Emails to vendors go unanswered. A phone call gets instant response. I believe it is their systems too that are available on ebay.
Old Jun 27, 2013 | 06:04 AM
  #34
ent72olds's Avatar
Registered Luser
He does sell on ebay, and he was very easy to deal with. I would be patient with him....his product is very nice.
Old Jun 27, 2013 | 06:12 AM
  #35
TripDeuces's Avatar
I used Classic on my 66 Cutlass. Although the fit is nice I thought the tailpipes are much to small in diameter
Old Jun 27, 2013 | 07:29 AM
  #36
Mine was 2¼", front to back, same as the original big block system.
Old Jun 27, 2013 | 02:20 PM
  #37
455Dave's Avatar
I also ordered off of EBAY for my 68 Ninety Eight. Since I was using NOS resonators (and Mufflers) I was ok with the resonator eliminator pipes because I really only needed the axle pipes. The car has factory duals and the pipes are the same 2 1/4 as original. The only difference was the head pipes came in 2 pieces instead of the original one-piece. Good quality and pretty quick delivery. Here are a couple of shots as I was installing the system. Dave
Old Jun 27, 2013 | 05:36 PM
  #38
Summerof84's Avatar
Good to hear he does good work. However, I have this thing called a job, so I am unable to call him during his business hours as those are my business hours too. I just got done replying to emails from my job at 7:30 PM, he could do that too if he really gave a hoot. Why bother to have an email form on the website if you don't ever reply?
Old Jun 27, 2013 | 07:32 PM
  #39
A number of us have described his product, and explained that we have found it to be of high quality.
If you don't want to buy his products because you disapprove of his business habits. that's up to you.
Old Jul 9, 2013 | 10:48 PM
  #40
delta7388's Avatar
Reproduction exhaust manifolds See Thorton Reproductions link below
http://thorntonmusclecars.com/products/manifolds
Crazy88
Apr 9, 2019 06:55 AM
atkinsom
May 29, 2013 06:39 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
65topless
Jul 12, 2007 05:28 PM
