heater core replacement 64 super 88 w a/c
So i went to start putting dynamat the floors and found a small puddle on passenger floor board of coolant. So my manual doesnt really go much into this. Not sure where to start, im assuming the heater box comes out from the inside. I guess there is probably nuts on the engine firewall side holding it in place. Has anyone done this that could give me some insight.
Your assumptions are correct. For how to instructions go here http://wildaboutcarsonline.com/membe...ection_15A.pdf
I see new heater cores on e-bay regularly for about $130.
I replaced mine about 4 years ago with one from Orileys Autoparts. It was around $65. I just checked their site for a 64 year with AC, and it was $49. Of course, these new cores aren't brass like the originals.
Well i got it out, i bent the upper passenger side stud, should be able to heat and bend back, not really sure how i could have gotten it out with out bending it. Does any one have any idea on what to replace the old seal? between heater box and fire wall, this one is just mush, i was thinking dynamat, both sides not really sure. Also going to try and find the vacuum, pots, ones got the input nipple busted off. Im sure getting it back in is going to be worse.
Tim Burleson
Jul 19, 2011 12:31 PM
